20 Most Recent Rockford Fosgate P3001 Car Audio Amplifier Questions & Answers
My Friend put A Rockford
Your friend has damaged his amp. The power light coming on means that the amp's power indicator LED is at least working. That light is only there to tell you that the amp is receiving power on it's 12 volt rails, not that it's necessarily using the power in any way other than warming up the amp's internal circuitry. When you say the amp gets power, I'm not clear on whether you mean the amp works in that fashion, or there's just a red LED glowing but nothing else happens. The amp needs to be repaired, and I would suggest to him to not apply power to it again until it is checked by a professional. The power supply has probably been damaged, and it's possible, depending on how the amp was mounted, that it was searching for ground through the amp's chassis if it was screwed into metal at its mounting location. All that seems certain as of now is that the LED works, but nothing else, unfortunately. If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
7/8/2017 10:09:14 PM • Rockford Fosgate... • Answered on Jul 08, 2017
3answers
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
6/11/2016 6:28:34 PM • Rockford Fosgate... • Answered on Jun 11, 2016
2answers
I was using bridge on a Rockford P300 and blew my
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. No internal fuses. Your mosfets are toast. A thumbs up would be greatly appreciated if this answer is helpful to you. using-bridge-rockford-p300-blew-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
12/19/2014 7:10:49 PM • Rockford Fosgate... • Answered on Dec 19, 2014
0answers
0answers
2answers
When i tried putting in the fuse the amp burnt all
most of the time it fryes the the finals in the units they can be repaired
depending on how partial you are to the unit it can be expensive
i no thats not what you want to here but its the bottom line
hope this helps you
bob
11/6/2012 5:55:22 AM • Rockford Fosgate... • Answered on Nov 06, 2012
0answers
I just installed a new xo vision x349nt dvd
Make sure and check the RCA wires in the back of your radio that send audio to the amp and make sure that they're connected to the OUTPUT/SUBS RCA's and not an input rca's. Also, check your ground and make sure no speaker wires in the subs are shorted. Try one speaker at a time see if that helps.
9/26/2011 4:28:19 AM • Rockford Fosgate... • Answered on Sep 26, 2011
Rockford Fosgate P3001 Car Audio Amplifier Logo
96 questions posted
Top Rockford Fosgate Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Rockford Fosgate Car Audio & Video
Most Popular Question
amps protect light
  • Car Audio & Video
