Could not delete printing job just prior to the error message. Turned on and off too many times perhaps? Now it says tell service representative error code c-EEE3 904-545-4800
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Testimonial: "Thanks.. Code was reset successfully "
I held the utility key down and turned it on.... Held down a little bit more..... Nothing happened..... Turned off, and waited 1 minute... Same code. Am I doing something wrong?
Press and keep pressed the Utility key and turn ON the copier,keep pressed the key will on the display displayed Trouble reset message,then release the utility key(during 1-2 minutes),after touch the trouble reset mesage turn OFF the copier and wait 1 minutes and turn ON.
It worked.... Seems like the key marked "access" had something to do with it also. Had to try three times... Thanks.
I'm not getting a trouble message to display
I only get the Minolta icon for a really long time after the hour glass goes away.
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
SOURCE: error code c-12cc for Konica Minolta biz hub c-350?
Error code C0520 on Konica Minolta biz hub c-350??
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
