20 Most Recent Konica Minolta Magicolor 4690MF Multifunction Laser Printer Questions & Answers
What make and model???
Konica Minolta... • Answered on Apr 02, 2020
replace the Yellow magenta and cyan image units Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Apr 01, 2018
check the code because not in the service manual Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Mar 04, 2018
empty the old one Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on May 07, 2017
replace the image units associated with the color of the streaks Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on May 06, 2017
What will the machine not do could not find that code Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Mar 11, 2017
If it physically doesn't go through, try to push a heavy stock card or decent thick laminated paper and try to feed it through. There maybe a mylar (plastic sheet) flipped backwards or a piece of debree stuck in paper path of your Document Feeder. This may resolve 80% of issue. The rest could be broken sensor flag (actuator) or dirty sensor that is not reading the paper passage (or it the sensor is faulty all together) The amount of staples, paper clips, Bluetag and other junk I pulled from ADF over the years..Bucket loads :) Good luck.
Konica Minolta... • Answered on Oct 01, 2016
check the sensor might be dirty Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Jul 09, 2016
yes what about it Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Jul 04, 2016
replace all image unit not using third party also check control panel settinigs for printer might be default to gray scale Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
as before check the network setting correct ip address cabling usb? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Jan 25, 2016
I would recheck the network setting first why where they changed??? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
then install a new one USE OEM not third party Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Jan 24, 2016
install the toner as required Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Jan 18, 2016
WOW. now that is a LEGACY Minolta Machine, Konica Minolta web site does not even list that machine try this site for a service manual Service manuals electronic components datasheets and equipment schematics... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
replace the black image unit and are you using third party toner if so get OEM Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... • Answered on Jan 16, 2016
Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
103 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Magicolor Konica Minolta
  • Magicolor Konica Minolta
Most Popular Question
konica minolta 4690mf paper jams in adf
  • Office Equipment & Supplies
