Do you know how to print on a CD/DVD?
I have just bought the same printer. if you have found out how to do this then excuse me. It isn't clear cut but basicaly all you do is :-
1/ Make sure you have a blank label stuck on your disc, you can also buy printable discs.
2/ Place the cd onto the cd holder label side up.
3/ Pull the front cover down - where the paper comes out.
4/ If you look carefully further inside where the paper comes out you will see another flap/cover - carefully pull that down.
5/ you will notice 2 little rollers and an arrow next to the right hand roller.
6/ place the cd tray carefully onto the rollers and align the arrows on the tray with th one on the ptinter.
7/ now your set for the software - open the CD Label Print software - click on new - click on image tab - and either image file or if it is from the scanner then select twain capture - if you select image file then either make your own image for the disc or select an appropriat file from the browes button.
I won't go on any more but just experiment, you will soon see how easy it is.
Happy Printing
