20 Most Recent Canon imageRUNNER 1023N Black and White Copier Questions & Answers
This printer only prints black and white. Canon do not supply Multi-color toner catridges for Canon Imagerunner 1023N
Canon... | Answered on Jan 10, 2018
you can scan by usb connection,
Canon... | Answered on Jan 28, 2015
Scott,
I would suggest checking the toner drum. You may be low on toner or if you recently replaced the toner, ensure that it is installed correctly.
- Scott
Canon... | Answered on Oct 01, 2013
I think then you should change the paper. if you are using right paper size then you should check settings.
Mercedes Performance Chip
Canon... | Answered on Aug 17, 2012
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Just find this:
- Service Manual -->> http://depositfiles.com/files/9qpwu3xlg
- Or try asking here -->> usa.canon.com/support
Hope this helps.
Canon... | Answered on Oct 20, 2011
u have to replace drum unit in your machine as a solution of this problem.
Canon... | Answered on Apr 18, 2011
the platen glass is small glass on the left side of normal copy glass. The platen copy glass is used when you making the copies from ADF.
Hope that helps
Canon... | Answered on Feb 13, 2011
you want to download system
Canon... | Answered on Nov 25, 2010
it could be few things,
Its probably drum unit fault, probably the cleaner is worn out and doesnt clean drum surface enough.Remove the drum unit and see if there is "leftovers" on drum surface and if Yes change the drum unit.
If the copie isnt baked enough that means that the fixing roller is worn out and you need to change it.
If You are using replacment toner, not genuine from Canon, also it can cause problems like bacground, dots, spots,...
Hope that helps!
Canon... | Answered on Sep 10, 2010
Do you have any files in the printer queue (the spooler)? Sometimes one file that had a printer can cause a lockup in the subsequent files you try to print. Try starting and stopping the spooler service.
In the command prompt (Start > All Programs > Accessories > Command Prompt) type "net stop spooler" without the quotes and then hit enter. On the next line type "net start spooler" again without the quotes followed by enter. When the prompt returns, reboot your computer.
Try a new data cable before you decide it is the printer. Also try using the Windows Device manager troubleshooting feature. (Right click on the printer icon in Printers and Faxes (Start > Printers and Faxes) and look for troubleshooting. Also try making it the default printer if it isn't the default (in the same place).
I hope this helps.
Canon... | Answered on Aug 13, 2010
try under: http://software.canon-europe.com/
The machine needs system software reloaded to take care of this issue
Canon... | Answered on May 15, 2010
from witch mechine
Canon... | Answered on Apr 05, 2010
it need to download the system software
Canon... | Answered on Mar 20, 2010
www.givememyfile.net see thier
Canon... | Answered on Jan 14, 2010
open the left hand door grab hold of the 2 marked levers pull out old drum then insert new 1 goodluck
Canon... | Answered on Nov 30, 2009
most likely someone has sent a print job in wrong papersize.....delete job in print que on copier
Canon... | Answered on Sep 30, 2009
tooth on gear might be breaking off, but maybe the toner cartridge is defective.
Canon... | Answered on Aug 26, 2009
Canon imageRUNNER 1023N Black and White Copier Logo
35 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
machine work words download
  • Office Equipment & Supplies
