Changed intel valve and pump. Cleared all holes and still no water. Starts agitating immediately
Sounds like a defective pressure switch that is just a spdt pressure operated switch and its stuck on the timer side of this switch and can't switch back to the fill side of the switch to fill the machine first before starting agitation,check voltage from the water fill wire off this switch for line voltage,then check from the wire on this switch to the timer for line voltage,probably no voltage from the water fill valve wire so it can't fill
SOURCE: Washing machine won't spin or agitate
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
SOURCE: No water is coming in the washer before the agitator starts
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
Most washing machines are controlled by software programmes these days and produce error codes if they don't detect the correct amount of water has been taken in within a set amount of time. The error code for not filling should be mentioned in the instruction book
Washing machine making a humming noise when trying to fill?
If the washing machine wont take in any water at all, plus you can hear a humming noise (not normally present), check that both your taps are turned on, or that the water supply hasn't been cut off in someway. A gentle humming from the back of the washing machine could be the water valves being energised and trying to take water in.
If water comes through at a decent flow rate then check the filter in the water valve on the washing machine. You can pull it out with a pair of pliers and clean it. However, this will only explain your fault if it is severely blocked up, which is rare. Be careful not to damage the filter with the pliers as they are often delecate and brittle. If you create a hole in one - even a small hole - it can let grit and even small stones through into the water valve and damage it resulting in possible flooding in the future if an obstruction stops the valve shutting off properly.
No adequate water supply coming through the hose?
If no water comes through the hose, or the flow is very slow, then the fault is in the plumbing or there could be a kink somewhere in the hose. If your machine was plumbed in using those self plumbing taps that clamp on to the copper water pipes then they do sometimes get clogged up and need the hole clearing. If this happens to the cold supply it can be achieved by turning the stop tap off first, but if the hot supply is blocked - which is the most likely of the two - then you have to turn off the cold supply and then drain the hot water tank by turning on the hot tap until the water is drained out (unless you know where the valve is to turn the hot water off in your water cylinder).
If your machine is plumbed in using the ubiquitous blue (and red) levers to turn the tap on and off they can commonly go faulty where you think you've switched it off or on but only the plastic lever has moved and it hasn't actually operated the valve inside the tap. This is typically caused when the red or blue plastic lever cracks. You can usually operate the tap using pliers.
SOURCE: Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
SOURCE: kenmore top load washer 29822800
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
