20 Most Recent Kenmore HE2 Plus 3.6 cu. ft. Super Capacity Front Load Washer Questions & Answers
He2 washer wont drain. easy fix?
chjeck the pump for any blogg
6/5/2014 3:02:37 PM • Kenmore HE2 Plus... • Answered on Jun 05, 2014
Kenmore front loader washer powers on but lets no water in
If the door lock is engaging, then there could be a few things causing the problem. These things are as follows:1) The water valve is bad - you can check this by seeing if when you turn the machine on if power, 115vac is being applied to it. If so the valve is bad, if not read forward.2) There is a part called the pressure switch, it controls the amount of water that flows into the machine. Its connected to the drum by a 1/4" tubing. You'll need to check to make sure that nothing is obstructing the tube.3) Take the bottom of the machine off, called the kick plate. Inside there is a tech sheet with diagnostic walk through's that will carry you the rest of the way If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
6/18/2012 4:15:02 AM • Kenmore HE2 Plus... • Answered on Jun 18, 2012
Wash Cycle will not start; add garment and door locked lights on.
IF you take the panel off the is below the door, there is a drain plug and you should take it out. YOU will get lots of WATER. Be ready. Clean this out and try again. The issue is most likely the water solenoid valve is bad or the board that controls it is bad. You can also find the tech sheet when you look for the drain. It has all the tests that you can run.
5/17/2019 11:44:46 AM • Kenmore HE2... • Answered on May 17, 2019
Leaky drain hose
https://www.youtube.com/results?search_query=replacing+model+110.4756+drain+hose. click on this link and review numerous videos you find there and although you might not find your exact model you will find enough info to do your replacement
1/15/2018 6:52:16 PM • Kenmore HE2... • Answered on Jan 15, 2018
0answers
I have an HE2 Model 110.47571601. The power will
There are two control boards (parts 3 and 6) shown here: http://www.searspartsdirect.com/model-number/11047571601/0582/0153200.html . Make sure to look at the Control Panel diagram. Part 3 is http://www.searspartsdirect.com/part-number/8540490/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . Part 6 is http://www.searspartsdirect.com/part-number/W10022320/0026/110.html?modelNumber=11047571601&categoryName=Residential%20Washers&brandName=KENMORE . With these part numbers, you should be able to find them online. They will be listed as Whirlpool or Whirlpool OEM parts. If you add a comment with the problem that led you to have a technician look at the washer, I will confirm which board is which. I suspect part 6 is the B board but I'm not certain of that. I hope this helps. Cindy Wells
4/20/2017 10:03:11 PM • Kenmore HE2... • Answered on Apr 20, 2017
I replaced the drain pump and now if I try to start machine all I here is drain pump humming. It wont fill or cycle. still have a F21 code
Have you looked into the water level gauge? It may be stuck
6/25/2015 1:41:03 AM • Kenmore HE2... • Answered on Jun 25, 2015
0answers
Kenmore HE2T front loading washer. Will not start cycle... hums, and then turns off. no error codes given.
make sure the water is turned on to the unit.
1/22/2015 12:07:44 AM • Kenmore HE2... • Answered on Jan 22, 2015
Have an HE2 washer. close door, select any cycle, press start, locks up then unlocks and shuts off???
unplug--see if it resets--if not--the control box is bad--about 300 for the part Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
1/13/2015 1:20:32 AM • Kenmore HE2... • Answered on Jan 13, 2015
Washer machine shakes when it spins and sounds like a helicopter landing- is not out of balance- and is leveled
sounds very like the bearing are gone i am afraid not good news its quite expensive to replace them if your machine is splitable
10/15/2014 1:21:37 PM • Kenmore HE2... • Answered on Oct 15, 2014
Kenmore HE2 Plus 3.6 cu. ft. Super Capacity Front Load Washer Logo
Popular Tags
16 questions posted
vince
Marvin
Marvin
View Most Popular
HE2 Kenmore
  • HE2 Kenmore
Most Popular Question
kenmore front loader washer powers but
  • Washing Machines
