SOURCE: error code C 6400
This code is a fuser problem code. Follow the procedure below. If the code does not reset or comes right back then: you will have to check the thermistor, thermo fuse and fuser lamp. If 1 or more are defective then replace. After you replaced the defective part you will have to clear the error code again.
Here's the way to reset that fuser code;
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
SOURCE: kyocera KM 1525 COPIER Showing C630 error
check the fuser unit thermistor and replace it......
SOURCE: MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
SOURCE: How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
