20 Most Recent Copystar CS-1620 Copier Questions & Answers
Bad FUSER
Copystar CS-1620... | Answered on Mar 14, 2019
It usually means the paper did not feed when asked. Check your exit switch and the registration switch in the paper path below the drum. If a jam was removed incorrectly one of those may be off its pivot and the machine thinks there's a paper there. Or the sensor itself is bad.
Copystar CS-1620... | Answered on Nov 28, 2014
THE CARTRIDGE PORES ARE PARTIALLY BLOCKED USE FORCED COMPRESSED AIR TO OPEN OR BLEED THE PORES AND THEY WILL WORK FINE
Copystar CS-1620... | Answered on Jul 19, 2013
try to press code 10871087 then 163 and lastly press clear/stop button for a while.
Copystar CS-1620... | Answered on Nov 03, 2011
cs 1620 does not support printing. The machine doesn't have printer option
Copystar CS-1620... | Answered on Aug 18, 2011
u cant .there is no method or way to do so
Copystar CS-1620... | Answered on Aug 08, 2011
press 10871087 press 163 press start button 5 times' ola
Copystar CS-1620... | Answered on Jul 25, 2011
down load it from kyocera website
Copystar CS-1620... | Answered on Jun 30, 2011
http://usa.copystar.com/americas/jsp/Kyocera/resource_details.jsp?pid=11917&rid=12081
The above link is model specific for your copier
http://usa.copystar.com/americas/jsp/upload/resource/12081/0/1620-2020ENOG1B.pdf
The above link is the user manual (.PDF) for the copier. Toner drawers are located on the front of the copier with a fold-down style of hinge. You hinge the door downward, pull out the old toner and replace with the new.
Thank you!
Copystar CS-1620... | Answered on Mar 28, 2011
go to kyocera site and download user manual. it usually comes as a cd when buying the machine
Copystar CS-1620... | Answered on Sep 13, 2010
press down the stop button for five second the reading on the display is the meter reading
Copystar CS-1620... | Answered on Sep 09, 2010
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Copystar CS-1620... | Answered on Apr 09, 2010
press 10871087 uoo will flash on screen then press print, D-L will appear, then press darker key find the letter c then print then email me the data that will appear [email protected] from then i will teach you on what to do
Copystar CS-1620... | Answered on Dec 26, 2009
flash firmware or reseat all connectors on Main and engine PCBs or replace main and engine PCBs.
Copystar CS-1620... | Answered on Aug 28, 2009
From my experience, this sounds like there is something still jammed in the document feeder. Either a torn corner of a piece or even a paper clip/staple/pencil blocking the path. There are of coarse other reasons but this by far is the most common. Good luck.
Copystar CS-1620... | Answered on Jun 26, 2009
Copystar CS-1620 Copier Logo
Popular Tags
31 questions posted
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
George Mclaughlin
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Copystar Office Equipment & Supplies
Most Popular Question
j00 error message
  • Office Equipment & Supplies
