Question about Copystar Office Equipment & Supplies
Where to find the inner tray on kyocera 3500i "inner tray is full of paper"
Abdirahman Warsameh
    New Friend:
Thank you really you helped me
Posted on Aug 09, 2017
Mike Lyste
    Champion:
    New Friend:
  • Copystar Expert
  • 250 Answers
If this were your problem it would be obvious the inner tray is in the middle of the machine there is a lever that lifts up as paper stacks up its probably stuck in raised position
Posted on Jul 12, 2017
5 Related Answers
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: kyocera fs-3900DN
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
Posted on Jan 23, 2009
Anonymous
SOURCE: coming up inner tray full
Technican came in
Posted on Mar 05, 2009
Kyocera HP Expert
  • 523 Answers
SOURCE: Can not get the output tray to use the finishing tray.
Do you mean you have internal finisher? Try to make any copy with staple it should comes out from there, if not you have to go to machine setting or copy setting , you do this by pressing menu buttom, and change the output paper to the internal finisher.
Let me know wat happen after.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Mar 24, 2009
Ray M.
  • 215 Answers
SOURCE: Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Posted on Mar 27, 2009
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: INNER TRAY
the inner tray is where the paper comes out under the top scanner part there is a paper sensor at the exit mark that tells you if you have paper in the tray and lets the machine know it has come out ok. check that it hasnt locked in place.. this can give a false reading too..Good luck
Posted on Oct 27, 2009
Testimonial: "Thank you"
Inner tray is full
Inner tray is where the paper exit...
Jan 03, 2017 | Toshiba Office Equipment & Supplies
Jam - remove paper from inner tray
open the finisher(sorter) door and pull out the inner tray. Remove paper
Apr 06, 2010 | Kyocera Ai3010 Copier
INNER TRAY
Oct 27, 2009 | Toshiba Office Equipment & Supplies
Kyocera FS2000D. Paper jam reported occassionally
this is problem with sensor you have to check all the sensors like
registration sensor
duplex jam sensor
paper exit sensor
face down tray paper full sensor........
easy way to solve this problem is remove Durmunit and toner box and rear unit then clean it useing a blower and refix all the componet and try...........
Oct 06, 2009 | Kyocera FS2000DN Laser Printer
Mar 24, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera fs-3900DN
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
6,536 people viewed this question
Top Copystar Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
George Mclaughlin
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
