I'm replacing the control panel on the microwave - how do I safely remove the ribbon cable from the blue receptacle to insert it into the new control panel? I don't see any clips on the blue receptacle unit which would release the ribbon cable and I don't want to risk damaging the cable by forcefully pulling it out.
SOURCE: How do i replace the keypad of GE Profile over the range microwave
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It will help you test the keypad with your meter.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you'd rather have us fix it for you, we do that for $39.95 plus parts.
DISCONNECTING THE KEYPAD
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip. (A pencil eraser is better and safer).
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
SOURCE: Removing the control panel on the 1800XL to replace the fuse
Unplug microwave. Remove the two phillips head screws from the top at the very front edge, allowing you to remove the top grill. This will give you access to the one remaining screw holding the control panel in place. Lift panel up a bit and you're in. Note: even an unplugged microwave can hold a nasty electrical charge if the bleeder resister inside the capacitor is bad. Be cautious and don't touch things unnecessarily.
SOURCE: My 3 1/2 yr old GE profile spacemaker microwave stopped heating.
Some components can be replaced from the front, but not the high voltage parts including the magnetron.
You can download GE
owner's manuals and installation instructions here. They make it easier to remove from the wall.
model number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If
it's within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
Some manufacturers will
send you the magnetron to do it yourself. If
nothing else, you can save about $75 by taking it to the shop yourself.
GE Customer Service is here if you want to request a magnetron.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: I need to replace the
1. Unplug the microwave
or turn off its breaker.
2. Open the door, then
detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without
disconnecting the wires.
If you have any trouble getting the grille off once the
screws are
removed, slide the hood vent grille to the left about 1/4", then then
pull it forward.
On some models there are L-shaped clips that fit
into a slot to hold bottom of the vent.
You can find helpful
number here.
They're our favorite supplier.
We're
1.
UNPLUG
THE MICROWAVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
2. 1. Remove the top front cover by removing the (2)
screws that are along the top edge (phillips).
3. 2. Slide the cover to the left about a half inch
(there are tabs holding the cover in place) and remove.
4. 3. Remove (1) screw from the top of the Keypad
Housing (phillips). Lift the Keypad Housing upwards about half an inch (there
are tabs holding the Keypad Housing in place) and remove. Be careful of the
metal grille that is just above the Keypad Housing as this may fall out since
it is being held in place by the Housing.
5. 4. Be careful not to pull on the wiring harnesses
that are attached to the Housing. Carefully unplug the wiring harness
that has the RED connector on it from the circuit board. Carefully unplug the
small white connector that has the mylar ribbon cable on it (this cable is
see-through and you can see thin, flat wires in it).
6. 5. Remove (4) screws that are holding the circuit
board onto the Housing.
7.
The Housing should now be free of the circuit board
and wiring harnesses. It's safe to let the wiring harness/circuit board hang
free, but caution should be used anyway.
8. 6. Remove the thin metal frame from the Housing.
There are (4) plastic tabs holding the frame in place. Using a small screw
driver pry one side of the frame away from the housing (try to do this to the
side that has smaller plastic tabs). When this side of the frame is free of the
Housing you have to lift the frame out at an angle to remove. It might put up a
fuss, but be patient and be gentle with it since the frame is thin and fragile.
9. 7. With the frame out of the way you will see the
mylar ribbon cable that is coming out from underneath the Keypad assembly. You
will notice that the mylar ribbon cable folds back onto itself as it re-enters
the Keypad assembly. This 'touching of the two ribbon cables' is where the
trouble lies. The ribbon cables may be stuck together. Carefully separate these
two and then insert a small piece of paper between them (paper can be 1/2 x 1/2
) and work the paper all the way down into the Keypad assembly as far as it
will go.
10. 8. Using electrical tape, apply a small piece
between the ribbon cables to hold the paper in place. Next, use more electrical
tape and put it between the mylar ribbon cables enough so as to keep the ribbon
cables separated.
11. 9. Re-attached the thin metal frame making sure to
press it into the Keypad assembly enough so that the (4) tabs click into place.
12. 10. Use electrical tape and apply it to the raw
metal edge of the thin metal frame to prevent the mylar ribbon cables from
rubbing on the metal edge.
13. 11. That's it. A final word of caution. Be careful
when inserting the ribbon cable connector back on to the circuit board. The
connector is loose and you need to gently place the ribbon cable into the
circuit board connector.
14. 12. Reverse the order of assembly from above.
15. 13. Plug in the microwave and then it should reset
and ask you to set the time.
16. Hope this works for you !!
