Xerox Workcentre 4250/SM Laser Printer, Copy/Print/Scan, 45ppm Print Speed, 1200 x 1200 dpi Resolution, 10/100/1000BaseTX Ethernet, USB 2.0 Logo
A
Anonymous Posted on Jan 28, 2013
Black lines on copies - Xerox Workcentre 4250/SM Laser Printer, Copy/Print/Scan, 45ppm Print Speed, 1200 x 1200 dpi Resolution, 10/100/1000BaseTX Ethernet, USB 2.0
How do I get rid of the black line when I scan or make copy's
I had a professional to clean the scanner and copy machine. The line was gone. He had special tools to clean the machine parts.. Hope that helps.
tip
Black lines on copiers!!
Hi!!
If you are making copies on a machine that has a ADF (automatic document feeder)on and your copies come out with black lines on them,but when you make copies from the glass there are no lines on the copies then the small glass on the left,has a mark on it!What i do is put the copy with the black line on,on the glass face up so you can see the line,now,more or less where the black line is on the copy,is where you can look on the thin strip of glass to the left,for a mark or thin line!!Clean it with a damp cloth and no more lines!!
Enjoy!!
Black line on the copy
black line on the copy.. try to clean the scanner flatbed and the ADF if black line still in the copy... replace the DRUM of your printer..
1helpful
Black line on copy and fax functions
Clean the paper path for the scan/fax portion. The original goes in and as the document is "read" a spot of dirt is causing the black line down the page because it is picked up in the copy area.
2helpful
2answers
When I fax it copies a black line is on the page. And when I copy from the top part it copies a black line. How can I fix that?
are you getting black lined copies while you are trying to send a fax or black lined images are obtained at the receiving end. Is there any problems while copying from platen glass. if it's ok, then check if there is any thing on the stream reading glass (the small sized glass plate meant for ADF) & clean it.
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Black copies canon laser class 510 only when using the adf. copies fine from the glass.
Are the copies solid black or black lines ? If there are black lines, try cleaning the **** glass under the ADF ( above the large glass ).
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
2helpful
2answers
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Black line on copies
If your copier has an automatic feeder and your line is present when using the feeder but not when you copy from the glass,just clean the small glass at the point where the line appears.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
