20 Most Recent Xerox WorkCentre 7328 Multifunction laser printer Questions & Answers
2answers
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
3/17/2021 9:43:36 AM • Xerox WorkCentre... • Answered on Mar 17, 2021
2answers
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
5/20/2019 2:52:22 PM • Xerox WorkCentre... • Answered on May 20, 2019
What does fault code on workcentre 7345 004-350
I face an Error code problame 004-350 please told the relief of this code
7/3/2018 11:42:35 AM • Xerox WorkCentre... • Answered on Jul 03, 2018
004-361 error code in xerox 7345
Hi Xerox Werk Centre 7428 Tray 2 NVM Read / Write Chain-Linc & Current Value
5/21/2018 9:35:36 AM • Xerox WorkCentre... • Answered on May 21, 2018
What does this code mean 009-349 on Xerox 7328 printer?
from what I found here Thread workcentre 7345 error code 009 349 It looks as if you will need a technician to service it
7/7/2017 12:28:33 PM • Xerox WorkCentre... • Answered on Jul 07, 2017
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
8/9/2016 2:21:00 PM • Xerox WorkCentre... • Answered on Aug 09, 2016
Error code 008-900
reopen the cover and look inside with a flash light, there maybe a tiny piece of paper stuck in there you missed, take some compressed air and blow it in there to clean out dust, the talcum powder on the paper, builds up on the sensors, making them think it has paper there.
10/8/2015 12:42:54 PM • Xerox WorkCentre... • Answered on Oct 08, 2015
009-349 key to reset
There's no reset for that error, the error indicates that the 1st BTR did not reach the retract position. Try clean the 1st BTR Retract Sensor and look for damage. Also check the gears for breakage.
8/11/2015 4:38:45 PM • Xerox WorkCentre... • Answered on Aug 11, 2015
Do u know the company that sell cheap xerox 7828 transfer belts
Try : eBay.com Just make sure you search by part number not machine model number. eBayeBay
7/7/2015 3:47:40 PM • Xerox WorkCentre... • Answered on Jul 07, 2015
0answers
How to change toner cartridge sensor in xerox workcentre 7345
Changing the Toner Cartridge sensor is not an easy task. However if you want to start playing with the internals, firstly you would need to remove external panels. some sensors look the same and are not interchangeable, but the ones that are, would be easy to spot. If you have a faulty cartridge sensor it would be interchangeable with the others. Try it, and see what the response you get. a Xerox service might pay you dividends. Good luck.
4/2/2015 11:05:42 PM • Xerox WorkCentre... • Answered on Apr 02, 2015
Cyan toner haze appearing intermittently on paper for a xerox 260
cleaning laser box
1/2/2015 6:00:22 AM • Xerox WorkCentre... • Answered on Jan 02, 2015
CODE 006-382 XEROX...
The error means that the interval of the ROS (C) signals exceeds the specified value. The normal problem is a bad mcu board. Measure the value between PJ401 on the MCU board and and ground for +5vdc. If you get +5 then replace the MCU board. Part number 960k31352. http://www.iteminconline.com/itemdesc.asp?ic=960K31355&eq=&Tp=
9/26/2014 10:51:13 PM • Xerox WorkCentre... • Answered on Sep 26, 2014
Xerox manual
116-314 is an ethernet address error. Can you ping the network port? Try reseat the eeprom on the main board. If the settings are all correct and none of that works, you will have to replace the main board, part number 960K39010. http://www.iteminconline.com/itemdesc.asp?ic=960K39010&eq=&Tp=
9/26/2014 10:45:03 PM • Xerox WorkCentre... • Answered on Sep 26, 2014
Xerox 7328 touch screen not taken
Hi, I share a links, so read it and follow instructions. If not understand then contact printer support technician and check it why your printer touch screen not working. Read more..http://www.office.xerox.com/latest/W73EG-01U.pdfand Xerox Printer Support Thanks,
9/5/2014 6:19:29 PM • Xerox WorkCentre... • Answered on Sep 05, 2014
Xerox WorkCentre 7328 Multifunction laser printer Logo
97 questions posted
Top Xerox Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Xerox Office Equipment & Supplies
Most Popular Question
009 349 key reset
  • Office Equipment & Supplies
