Dell 1135n AllInOne Laser Printer Logo
Posted on Dec 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door Open error message - Dell 1135n AllInOne Laser Printer
vedha
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 27, 2013
vedha
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
292
Points
Anonymous
Level 2:
Sergeant:
  • Expert 475 Answers
  • Posted on Dec 29, 2012
Anonymous
Expert
Level 2:
Sergeant:
Answers
475
Questions
0
Helped
112447
Points
908
You might have to unplug everything for the computer and plug it back in again.
Sanyo DW-MS600F error message saying door is still open
Sounds like the door interlock switch electrical connector is failing to make a connection. You can open the panel and inspect the lock to confirm. Clean as needed (Please remove power from the unit at the circuit breaker panel before opening the door panel).
Jim
Mar 10, 2014 • Dishwashers
2helpful
2answers
Samsung CLX-3185
Hi
Have you checked the cartridges access door?
If so,try disconnecting the printer and leaving it for a long period [like 1hr] before connecting again.
3helpful
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
2answers
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
1helpful
"Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Wont print-message says door open, but no door is open
Same printer works fine on another PC. Unfortunately.
2answers
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Sony Mavica MCD250 -"Door Open" error message
have that opened up in a service center and tell them that you dropped it. they will tell you that the sensor is busted. that will have to be replaced. hope this helps.
fixya!
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
