Refrigerators Logo
Posted on Dec 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung fridge RS2555SW is not working. all temp lights are blinking. can you help
RS2555SW is the model number. Both temperature lights are blinking and freezer and fridge are getting warm. We bought this used so there is no warranty. Can you please help?
raj somaiya
Level 3:
  • Master 5,370 Answers
  • Posted on Dec 22, 2012
raj somaiya
Master
Level 3:
Answers
5370
Questions
0
Helped
3571096
Points
14579
May be it needs reset. Unplug the unit for 12 hours and then reconnect to see if that makes any difference.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
5 Related Answers
Anonymous
  • Posted on Mar 25, 2009
SOURCE: my fridge freezer made by samsung is on the blink
These fridges have an evaporator fan motor on both sides - the freezer and fridge side. The freezer can maintain it's temperature because that fan is working fine. I had the same problem, and replaced the evaporator fan motor on fridge side, and it solved the problem. Also, if your fan motor is not working well, or stops working, the evaporator is prone to ice build up, and will prevent proper cooling. You may want to open up panel on fridge side and see if that's the case. Taking a blow dryer to the evaporator and surrounding area (while fridge is off), or letting it sit for a few hours might solve the problem. Ultimately though, it appears as if these fan motors are prone to failure, and need to be replaced.
A
Anonymous
  • Posted on Feb 04, 2007
SOURCE: temperature adjustment
Answer the question is 1/2 or 4/5 colder?
A
Anonymous
  • Posted on Feb 26, 2008
SOURCE: samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Anonymous
  • Posted on Mar 08, 2008
SOURCE: Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Anonymous
  • 1606 Answers
  • Posted on Jun 27, 2010
SOURCE: fridge broken, freezer is temp. that fridge should
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . ( If you notice your compressor is not running before unplugguing the blue plug , then jump wire1 to wire3 to see if the compressor runs . If so , then the main control board is bad . Plug the refrig back in to see if compressor starts with the jumper wire in place , ) . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Samsung RT18M fridge off light flashing?
Pull the plug out, count to 20 and plug it back in as a start. Lots of help here
Samsung refrigerator temperature display is blinking
Samsung US https://www.samsung.com > support > TSG01002092
A blinking temperature display is trying to get your attention, typically because the temperature is too high and things need to cool down.
Samsung Refrigerator Temperature Display Is Blinking
Samsung US http://support-cacyber.samsung.com > popup > iframe
The temperature display or temperature bar on your fridge will blink if the temperature inside the fridge is above 59 degrees Fahrenheit. It will automatically ...
Missing: RT18M ‎' Show results with: RT18M
Why Your Samsung Refrigerator Display is Blinking
appliancegeeked.com https://www.appliancegeeked.com > how-to-fix-samsu...
Dec 21, 2022 - A blinking temperature display on your Samsung fridge suggests a temperature error. The most common cause for this is warm air trapped inside ...
We just bought Samsung Refrigerator RT18M"/RT21M and ...
JustAnswer https://www.justanswer.com > Appliance Repair
Sep 23, 2022 - The freezer display lights are blinking. There's recently a · The freezer display lights are blinking. There's recently a thin layer of ice on ...
1 answer · Top answer: Hello, my name is*****'m here to assist you today, can you provide a model number..
Temp sensor
Check for broken wires on your ice maker temperature sensor. On my model RF265AABP that was the problem causing display to read 88 88 with one digit blinking.
3helpful
Strange code on temperature panel, blinking 88 88/A8 w/no respons
Press both power cool buttons at the same time, until you here a chime (about 3 sec). This should solve the problem.
FIT FiNallee
1helpful
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
THe freezer is working fine, but the fridge is not cooling very well MODEL HTS22GBPBRWW
samsung RS2555SW the freezer temperature is 58 tryied to changed to -4 it goes back to 58
5helpful
2answers
Dash light on monitor no refrigerator temperatures shown on monitor how to reset
Hi there, I have the same problem with my samsung side by side the model no is- RSA 1Wtmh .
The light started blinking after a power cut and the elec came back on and the fridge light just blinks on panel instead of showing temp (the fridge and freezer are working)?
49helpful
7answers
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
