I will put it on charger and the power and the power light turns orange after a while it will turn green and then i will take it off and try to turn it on and it will not turn on. How do i fix it?
To everyone that's having problems with not booting up or the back plate battery cover warning messages on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
welshcob
SOURCE: dell x50v won't turn on
while pushing the power button , push reset button for couple of seconds. hope that helps as that is what worked with mine.
SOURCE: Dell Axim x50v PDA turns on when screen is tapped
If your PDA turns on when u press buttons if u go to settings u choose if u want it to turn on for any button or just the main button
