Maytag Neptune MAH6500A Front Load Washer Logo
A
Anonymous Posted on Nov 15, 2012
What does ph mean?
After completing a wash, the machine keeps chiming every minute or so and flashing ph
1 Related Answer
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Oct 08, 2010
SOURCE: my washing machine starts on
F50 Code is telling you the motor has stalled.
Check to see if the tub is locked. (won't turn) If locked find out what is causing the friction. If it turns freely download this manual:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3fb1b0a63366238b852572c3006ea9ce/$FILE/8178643.pdf
First see page 65 for code read out then follow the steps on page 72 / (6-10) Test 3
There is a problem with RPM sensing / Motor control board / motor assy
Thanks for choosing FixYa,
Kelly
Sud flashing on kenmore elite he5t washer
Are you getting the little melody chimes! Mozart? I read that about the Kenmore's. Your adding either too much soap or the wrong kind. Read owners manual for proper amounts of soap! More does Not mean more clean!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
2answers
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
2helpful
It keeps stopping flashing LF,I don't have the manual,what does LF mean?
Hello there:
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. furthermore please check the following that may apply
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve. There's no water at all If there's no water at all, make these checks: Is there water getting to the machine? Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet
Chime is no longer working. Stopped sounding at completion of wash cycle
Is chime built into the timer? Leave alone. if it is separate then replace chime
2helpful
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
1helpful
Washing programme keeps stalling
Ok, this is a basic control fault within the logic chip set. you will need to replace this faulty control board/timer in this case.the replacement of the control/timer will fix this issue.
76helpful
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 • Watches
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
