Used yesterday. Today will not turn on. other devices using same power strip are working. Tried printer on other outlets, still will not turn on.
SOURCE: I had a power outage
Chances are it has blown the main fuse in the power supply, and perhaps done some additional damage to some electronic parts. The printer must be dis-assembled to make that determination.
SOURCE: Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
SOURCE: chip/no chip issue for Canon Pixma MP530
the printer NEEDS ink cartridge WITH the chip
BUT, you can move the chip from the old to the new cartridge, you just lose the ability to monitor ink level....you have to visually check it from time to time
been doing it for months now... works fine, just keep a close eye on the ink when it starts to get low, can hose the printhead for that color if empty
printheads run around $55 or so - so actually, savings in ink will easily pay for a new printhead every now and then, if you screw up :)
SOURCE: Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
SOURCE: Canon PIXMA MP530 All-In-One InkJet
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit
- Logic board
- Purge unit
Good Luck
