Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon PIXMA MP530 All-In-One InkJet Printer Canon mp530 error 6a00
Posted by vendas215 on
Computer Links
  • Canon Master
  • 2,386 Answers
Hello
Unfortunitly this is not an easy fix. IF you still have under warranty you can contact Canon and they will fix it. If its not under warranty they can refer you to the nearest Canon Service center.
The 6A00 error is an internal error which can be caused by one of the following things.
- Sheet feed unit - Logic board - Purge unit
Good Luck
Posted on Dec 15, 2010
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like
Dec 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Says Check printer 6A00. Any ideas?
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. Thank you
May 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Show the code 6A00 and the printer won't print. The lcd reads check printer then flashes 6A00
That error indicates a sheet feeder error, apparently its not something you can fix yourself and you will need to send it in for repair.
You will need to send it too an Canon approved repair center, calling Canon and asking them should reveal where to send it.
Aug 31, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Display Shows Error 6A00 and it Doesnt Work ahead
6A00 is a problem with the sheet feed unit.
Follow Canon's suggestion, take it or send the unit UPS to the Authorized Repair Facility.
You will NOT be able to resolve the problem yourself.
Jun 01, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Check printer and 6A00 flashing
6A00 indicates that "an error occurred in the AP motor
during purging operation". This is a service call error and requires that the printer be brought into a canon authorized service facility for repair. The service facility would be able to fully diagnose the problem and properly repair it.
May 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : [email protected]
Sep 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
ERROR 6A00
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=832&modelid=13371&keycode=2118&id=27509
this is a script error which can be fixed using this link i looked up the information for you.
just download from link this should help
May 07, 2008 | Canon PIXMA® MP530 All-In-One Printer
Canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
497 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
