SOURCE: Whirlpool Gold Quiet Wash Plus
Hi First make sure that nothing is blocking the drain pump
assembly located inside the lower front panel of the dishwasher. If the issue
returns after its cleaned then try to reset the dishwasher control by pressing
the AIR DRY button and hold it for 15 seconds, if its still not resolved
then it means that the control board has gone bad and should be replaced. Hope
this helps...please post back for further assistance. Daniel
SOURCE: Whirlpool Gold Quiet Wash Plus quit working and no lights come on now
The first thing I would check is the latch. If it is not engaging properly then nothing will work. It is simple to check. Set it to run. Open the door a little and take a flat screwdriver & press the inside part of the switch in. It is like a button. You my get a little wet but you may find the problem. The latch can get out of whack. If it is one that has adjustments on it then loosen screws and adjust to make it seal the door tighter. a few models you have to bend the latch to adjust. I hope this helps.
Testimonial: "You sir... are a genius!!! I tried pushing down the latch in the door and all the lights came on. I did not get wet either (as the timer was still set for 2 hours). I used a butterknife to bend the metal latch/hook down a tad and now i have a working dishwasher. Thank you X 1000!!!"
