SOURCE: Haier portable air conditioner HPRDXC5
I just bought this A/C unit today for $649.99 CAD, and it won't cool the room down...small room and I had it on for 3 hours, and it's still 32°C in here...taking it back to Best Buy tomorrow for a full refund. 'Red light is on' means that the water tank is full, as stated in the manual. Open the rubber plug at the bottom rear of the unit and empty out the water so that the unit can function. If this doesn't help, or there is no water in it, the electronics are probably messed up and you will have to send it for repair or replacement. Good luck...
SOURCE: Haier air conditioner
On the Compressor? - Theres a run (R) that gets the red wire from the run capacitor or line side voltage, theres a start (S) that gets the yellow wire from start capacitor and theres a common (C) that gets the black wire which connects to neutral or common. If you ohm it out to identify the terminals the highest resistance is between (S) and (R) second is between (S) and (C) and least resistances is between (R) and (C). Hope this helped. GL!
SOURCE: I have HAIER HPAC 99ER Portable air conditioner
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
SOURCE: My portable air conditioner Haier started linking
Hi. Check the drain hose and look for kinks and partial blockage. Even algae can often block these tubes. J.
Testimonial: "There was dust covering the entrance of a tube where the water used to flow and evaporate, it was right beneath where the air filter is located. Removed the dust and is working fine again. Thank you"
SOURCE: I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
