Question about Haier HWR08XC7 Air Conditioner
The styrofoam inside the unit is covered in black mold. I was wondering what i should do if anything.
Posted by bigbird6183 on
ADRIAN
    New Friend:
Any mold in any part of the unit is not good, especially if its in the Styrofoam, Styrofoam has pores and hides the mold spores well, it would be dangerous to actually run the unit with mold spores as it can travel inside the house. Unfortunately companies that make these units don't make these units mold proof, why should they? that's how they make their money. I have three units, one has always given me problems with mold. It always comes back. The other two are always clean. My best advice, get rid of the unit and get another one or get a free estimate on Central air and heat. Mold is very dangerous and is not worth the risk, it can cause a number of medical issues.
Posted on Sep 04, 2013
Dona Wilbe
CAN YOU BUY A AIR CONDITIONER THAT DOES NOT HAVE THE STYROFOAM INSIDE?
Posted on Apr 25, 2019
5 Related Answers
VtToolMan
Mark
  • 704 Answers
SOURCE: mold inside the home unit
You can use a spray bottle with 100% bleach in it to kill the mold. After spraying the gunk, you can put on some rubber gloves (those dishwashing ones are a good choice) and use some paper towels to wipe up as much of the mold as you can reach.
Spray more bleach on the parts you're cleaning to keep sanitizing the A/C unit and wipe everything dry. You should put all the stuff you used for cleaning it up (paper towels, gloves, etc.) into a plastic trash bag,
I'd also recommend that you do this when any small children and pets aren't in the room you've got the A/C in, and also wear a face mask to keep from breathing in anything that could cause a respritory ailment.
You can also use some Lysol disenfectant to give the whole unit a nice going over, once you're done, to be sure that you've killed any active mold spores. It might be good to give the unit a once-a-month cleaning to prevent the growth of mold in the future.
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
mastatech
mark milligan
  • 478 Answers
SOURCE: IS THERE SUBPOST TO BE STYROFOAM INSIDE THE AIR CONDITION UNIT
Yes, they mostly juust use it for air flow
Posted on May 10, 2009
Anonymous
  • 254 Answers
SOURCE: styrofoam inside of my Haier HWF05XC7
It should remain there it is the insulation seperating the condensing side from the evaporating side you may nve to reach in and move it around to prevent the destruction of the foam.
Posted on Jun 22, 2008
Anonymous
  • 17 Answers
SOURCE: mold inside unit
There is a product on the market that will prevent mold from growing in your air conditioner.You should be able to find it at a refrigeration supply house.Just take the product and place it in the area where the water collects.There is also a product to help you clean your unit of contaminants on the heat exchanger surfaces.It simply sprays on,and can be later rinsed off.Its usually a straight forward matter to remove the cover from an air conditioner.Usually no more than 4 screws.Some units will slide out of their covers,after removing the screws that keep them locked in place,and some covers simply lift off from the rest of the unit once the screws are removed.In either case the rest of the unit minus the cover will remain intact,and can be cleaned.Cleaning the unit will almost always make it work better too,so your killing two birds with one stone.
Posted on Jun 26, 2009
Anonymous
SOURCE: had leak and now inside unit is covered in mold.
I have an amcoreair duo, that all of a sudden will not turn-on. I know there is energy going to the unit; however the unit will not respond or turn -on from the remote. Anyone have any ideas?
Posted on Feb 19, 2010
My ac window units are not draining water and creating mold in my house
Check the drain tube between the evaporator side to the back of the unit. It may have a packing plug installed. If there is one remove it or clean the drain tube.
Jul 23, 2014 | Frigidaire FRA08PZU1 8,000 btu Window AC...
We have a frigidaire a/c wall unit with mold. Problem is the inside is styrofaom and scrubbing it will destroy the styrofoam How do I clean it??
Unplugg it , spray bleach on to effected area .wait till mold is gone then plugg back in. Make sure to Keep the filter clean
May 30, 2013 | Washing Machines
My Frigidaire Window Ac Unit is Collecting Water on the Styrofoam Thats Facing Inside The Home By The Vents,Why Is this Happening?
tilt your ac down on the outside,so it will drain properly,if that doesnt help,pour some bleach in the water inside to get rid of mold that clogs the drain
Apr 18, 2017 | Heating & Cooling
Black mold inside unit, fan becoming noisy, I have a hunch that it,too, is covered with black mold.
It sounds like you know the problem and the sollution is to clean it. these system require rutine cleanings every 6 months because they have condensation always in the pan
Aug 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
MY SHARP AF120FX ALSO DOESNT DRAIN AND THERE APPEARS TO BE NO DRAIN HOLE AND THE UNIT HAS ALWAYS BEEN ON AN ANGLE. THE UNIT FILLED WITH BLACK MOLD ON THE STYRO FOAM INSIDE TOP OF UNIT SO I SPRAYED IT WITH...
Many newer units are made to retain the water and splash it onto the condenser coil... Clorox in the water will kill the mold and not hurt anything... You can carefully drill a hole if you want..
heatman101
Asker's Testimonial " good knowledge, very helpful thank you " - rubicon1952
Aug 19, 2010 | Sharp AF-S120FX Air Conditioner
Black mold in broken Dishwasher
bleach is always good i suggest you cover the dishwasher with a good plastic film after you spay it with bleach to keep the mould inside it till you can remove it
Dec 17, 2009 | Dishwashers
Mold inside the home unit
Aug 22, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mold inside unit
Jun 26, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
I makes a very loud noise
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
Jun 02, 2008 | Heating & Cooling
Styrofoam inside
you may open and remove foam not included in unit , be sure return make align everything.
Jan 01, 2008 | Kenmore 335 CADR Air Purifier
Haier HWR08XC7 Air Conditioner Logo
12,888 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
JOHN LAPIER
Steve Pack
Steve Pack
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
