20 Most Recent Haier HWS08XC1 8,000 BTU Window Air Conditioner Questions & Answers
Room temperature sensor weak. Replace it.
Haier HWS08XC1... • Answered on May 02, 2019
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Haier HWS08XC1... • Answered on Dec 08, 2015
Haier offers window and portable AC units to fit your space and keep the temps ... Haier window air conditioner ultra quiet serenity model. ... Coming in at 43 dBA, it's the quietest window AC on the market*. ... Get AC When & Where You Need It ... excess moisture is removed from the air without you having to empty the unit. For more click here
Haier Heating &... • Answered on Apr 23, 2021
That error is a freezer fan motor error, Check to see if the unit is defrosting like it is supposed to be. IF it is defrosted, check to see if the motor spins and if you have a meter for measuring resistance, check the motor windings. If they show no conductivity, Replace the fan.
Haier Heating &... • Answered on Feb 23, 2021
Nothing is broken and you don't need to print off anything or order anything. There is simply too much water in the drainage tank.
Unscrew the spicket at the rear bottom of the units and pull out the plug. Let the water drain. It will work again immediately.
Replug. Rescrew. Enjoy.
Haier Heating &... • Answered on Jul 12, 2020
the flashing red light indicates that the water collection tank is full
Haier Heating &... • Answered on Jun 05, 2020
Really not enough info to give a good answer yet... was it cooling your home good before you switched to heat? If it wasn't, then most likely your system is low on refrigerant... when it is suppose to be on, check to see that your outdoor unit is coming on, if it is on and the outside unit looks like a block of ice or starting to ice over, the defrost control board has failed and needs replaced.. hope that helps
Haier Heating &... • Answered on Oct 05, 2019
Their a sealed system..only way is to install a piercing valve...good luck they usually always leak after that... but it won't fix the problem you need to find the leak..good luck
Haier Heating &... • Answered on Jul 15, 2019
Heating & Cooling Logo
13 questions posted
Top Haier Heating & Cooling Experts
Tom Chichester
john h
Steve Pack
Steve Pack
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Haier Heating & Cooling
Most Popular Question
voltas ac error code e 1
  • Heating & Cooling
