Its probably full of water.. In the back at the bottom center is a screw on cap. Under that is a rubber stop... Pull those and drain the water.. It worked with mine..Its probably full of water.. In the back at the bottom center is a screw on cap. Under that is a rubber stop... Pull those and drain the water.. It worked with mine..
You can't post conmments that contain an email address.
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Have you checked the troubleshooting section of the owner's manual? If you do not have the original it can be downloaded from the manufacturer's website.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
