No standby light, red or blue, tv is not getting power. Tried different outlets and cords.
SOURCE: 55hds69 hitachi plasma
First, try the unplug it, wait a few minutes, plug it in trick, several
times. If that doesn't work try pressing the power button and slap the
back left side of the set several times. Sometimes, this will shock the
ballast and/or lamp into working.
Try checking the wires as well if its pinch or not and try to take out all cables from other devices from the back
SOURCE: Can turn on to red light and get blue light, but no picture
The mainboard needs to be replaced
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
SOURCE: Hitachi P50T501 plasma tv powered off.
Your TV has a bad power supply on it. Ask the repair service technician to fix your tv.
SOURCE: Hitachi Plasma not getting power
I have the same tv with the same problem. I plug it in and press the main power button on the bottom and the orange standby light comes on. Then i have to press & hold the power button on the side for 5 seconds and let go and press once for the blue power light to come on. I still get no picture. I've pressed the menu & input buttons on the side to see if those would open but nothing happens.
Any ideas on that?
thanks in advance
seth
