Question about Hitachi P50H401 50 in. Plasma HDTV
I have a hitachi 50 "plasma that was given to me
Posted by ANGELIA SOLIS on
  • Hitachi Master
  • 6,120 Answers
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Posted on Jul 11, 2011
Hitachi 50HDA39 Plasma Burnout
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Troubleshooting procedure to many popular brand TVs are given. Surf the site with patience.
Jan 19, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
How many years warranty on Hitachi P50X01AU plasma?
That depends on your country, who you purchased it from and any dealos that you have been given at the point of sale.
Yes, a mine field!
Jan 20, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Plasma 50 inch H4011 series just went off and red light blinked 4 times. Won't come back on even after unplugging and waiting 30 seconds and plugging back in per Troubleshooting guide in owner's...
Power supply board is dead.Replaced the power supply board,Ur tv will get the power back.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for replacement.
Feb 21, 2010 | Hitachi P50H401 50 in. Plasma HDTV
I have a 2006 Hitachi Ultravision 42 inch plasma
plasma tv units use a lot of power ,well into the hundreds of watts 9 some big screens use up to 800 watts to work)
I suggest that you consider a new led unit which uses barely any power and you will get a remote with it
Jun 24, 2017 | Hitachi UltraVision 42HDS52 42 in....
Hitachi P50T501 plasma tv powered off.
Your TV has a bad power supply on it. Ask the repair service technician to fix your tv.
Jul 27, 2009 | Hitachi P50T501 50 in. Plasma HDTV
My hitachi plasma TV P50A202 screen is black and the blue indicator is blinking
unplug unit for 1 minute turn off main power button plug in then press main power button and try!
Jan 10, 2009 | Hitachi P50A202 50 in. Plasma TV
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
NO POWER!!!
I could be one of your fuses, the only problem is you have to take it appart and if you don't know how is better to take it back where you bought it.
Apr 13, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi 50" plasma no picture
how do i fix p50h401 blue light no picture and sound
Feb 07, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi P50H401 50 in. Plasma HDTV Logo
605 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
