CONECTING AND DISCONECTING MOVED THE CORDS PRESSED ALL THE BUTTONS MOVED IT TO ANOTHE WALL I THIUGHT MAYBE IT WOULD BE WHERE I HAD IT CONECTED OR SOMETHING
How old is the set The older models suffered from problems with the electrolytic capacitors in the power supply . No point in trying another power outlet or cable if the standby light has been flashing red . Power is obviously getting to the set if the standby is lit .
Has the set been a little slow staring from cold lately
If tried a different power outlet and still not working, tv need for repair
SOURCE: i have a samsung LN32A330J1DXZA
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
SOURCE: Flashing red light on front of Sony Wega flat screen tv
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
SOURCE: my LE32S7 tv wont switch on. red light at
check for dry joints on power pcb, look for leaky caps on same
SOURCE: when i plug in my samsung 32 lcd the power button
after internet search i discovered a problem with the capacitors or something like that. looks like you can buy inexpensive replacements at The Source / Radio Shack and replace them yourself.
a good link for help:
http://forums.cnet.com/5208-13973_102-0.html?threadID=316414
Hi Marisol Soria, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Model and such.
