I changed the toner into a new one. But it displays "no toner catridge error". I bought two of these copiers at the same time. This same toner catridge was taken to the second copier of the same model and it worked perfectly. What do i do to resolve this error?
SOURCE: Sharp Am - 410 Copier
My Sharp printer AM 410 is showing in the header fuser temp error what show I do
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: F2 error
"F2-31"
Image density sensor fault
"F2-32"
Drum mark sensor fault
"F2-33"
Grid voltage correction problem
"F2-35"
"F2-37"
SOURCE: Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
