SOURCE: AC adapter cut out ? Home docking station
I have this problem too with my TAO xm2go, and that company is no longer around. But, after searching, I found there is no solution for this problem. Sorry!
SOURCE: Amp turns off after about 5-10 minutes of use for a few seconds
One of two things...Amp is going into overload protection (should be indicated by a light on the amp), or you have insufficient power going to the amp....if this is the problem, try a 2 farad capacitor on the input power line to the amp.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
SOURCE: after unit is on for about 15 minutes it clicks
First I would like to verify that the buzzing noise is from the speakers, and or subwoofer and goes up and down with the volume control. 2nd if it is a noise inside the receiver then that would take us in a different direction, possibly to a chattering power or speaker protection relay.
Back to the intent of the first post, I was trying to determine if you were getting an analog hum or digital processing error in the audio.
So knowing which input, surround, on/off, DSP on/of settings would steer us in the proper direction.
The turn off pop is interesting, because it may indicate a voltage off set being applied/removed to the speakers or an audio processing malfunction.
An experienced technician would first verify the power supply voltages, speaker offset voltages and bias, and then isolate to the analog or DSP section.
Thank you for using FixYa
SOURCE: I installed the pioneer DEH-1300MP
You may have a bad speaker. Are you using the stock speakers or aftermarket speakers? If you can, check the resistance of the speakers, they should be around 4 ohms or so. If they are less than 3, they are probably bad, You may also have a bad output Ic.
