Question about Pioneer TS-A6955 Coaxial Car Speaker
Which terminal is positive and negative on Pioneer car speakers. thnaks Shane
Posted by shanepics55 on
  • Aaron Bryant
    Aaron Bryant Jul 02, 2017
    The ground should be the bigger terminal on pioneer sony does it just the oposite. But the main thing is to make sure you hook all speakers up the same or you will have whats knowb as an out of phase situation (no bass because speakers are cancelling each other out) if you dont like the way it sounds reverse the wires and try it again the difference in quality will be noticable.
Anonymous
    Genius:
  • 1,672 Answers
Look closely at the terminal of the speaker, the size is different from positive and negative.
The bigger terminal should be positive( + ) with a stamp mark on the terminal itself.
The small one should be the negative ( - ).
Hope that helps you!
Thanks for using Fixya!
Posted on Dec 11, 2010
Rod Amo
    Habit-Forming:
    New Friend:
  • 64 Answers
Positive has a small black or red line
Posted on Jul 02, 2017
Daryl Sicignano
    New Friend:
    Problem Solver:
  • 8 Answers
There are no stamped polarity marks on anything on a set of Pioneer TS-A680R speakers, these speakers say CUSTOM-FIT for Ford/Mazda right on the side of the box. It's a good idea to check the factory speaker wiring colors, looking for the solid color being positive, and the striped color obvious being negative. Also these particular speakers have only one wider terminal blade with a included solid white wire with corresponding terminal, suggesting positive.
Where can i find a radio diagram for a 24 pin 05 cobalt with pioneer speaker system
Car Radio Battery Constant 12v+ Wire: Red/White .
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Factory amplifier is located behind the driver side of the dash (near the firewall).
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Dark Green
Right Front Speaker Positive Wire (+): Light Green/White
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Brown/White
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Tan
1helpful
2answers
Which side is positive on a ts a1365 speaker?
Take a 9 volt battery, 0r Evan a 1,.5 volt battery will work, Hook up to the termanals on the speaker ,When the cone draws in ward you no you have it hook up right,
I need a color wire diagram to connect a pioneer head unit to a 96 chrysler concorde
GM speaker wires are usually purple, green, grey, and white if I remember right. 12v should be red and ignition should be yellow you can verify with a multimeter and use a battery to test positive/negative on speakers by connecting the battery to the speaker terminals if the speaker pushes outward the positive is connected tothe positive terminal
3helpful
What wires are for what on my kd-g200
The cables for you In-Car stereo are as follows:
Black - Earth to to the chassis.
Yellow - Live that should be connected directly to the car battery and not the igniton.
Red - To an accessory terminal in the fuse block.
Blue / White stripe - To remote antenna (if fitted)
White / Black stripe - Front left speaker (negative terminal)
White - Front left speaker (positive terminal)
Grey / Black stripe - Front right speaker (negative terminal)
Grey - Front right speaker (positive terminal)
Green / Black stripe - Rear left speaker (negative terminal)
Green - Rear left speaker (positive terminal)
Purple / Black stripe - Rear right speaker (negative terminal)
Purple = Rear right speaker (positive terminal)
That covers all off the cables that you should have with the car stereo.
4helpful
3answers
Which is the positive and negative connection on the back of the speaker
Normally the positive terminal is larger than the negative terminal. If not the case here, look closely where the leads route to the mid and tweeter. The terminal that leads to a cross-over component (capacitor) is the possitive terminal. (old school way of thought, but it works)
How to
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
6helpful
Connect positve and negative speaker wires
The slim terminal is the negative and the fat terminal is positive.
please rate, thanks
How to
First of all, make sure your amp is bridgeable. There are a few ways to bridge subs. series: hook one wire from the negative on the left amp output (or whichever is labeled on amp for bridged)to left sub negative. left sub positive to right sub negative, then right sub positive to the amp positive output.(like a big loop through both speakers) parallel: both speakers get their own set of wires, both negatives go to the bridge negative terminal, and both positives go to the positive bridge terminal. Series-parallel: A combination of the two. say two speakers in series, and one hooked up alone, but all to the same amp outputs. Bridging your amp/speakers basically lowers the resistance of the circuit and makes more current flow, more power, louder, harder hit. In series, it also makes both speakers do exactly the same thing, instead of "stereo sound" or L/R differences. What you're probably looking to do is Bridge in parallel. That will drop the resistance of the circuit the lowest, allow the amp to put out the most amount of current to the speakers, and allow your bass to hit the hardest. If your amp only has one output, hook up the same way as above. Just see what resistance your amp is stable down to. If down to 1 ohm, no worries. if stable only to 2 or 4 ohms, you may want to bridge in series to be safe. That will cause the resistance to go up, and will not pull as much current through the amp. The whole time, just remember Bridgeing and higher current mean HEAT so watch your amp. I hope this helped.
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Pioneer TS-A6955 Coaxial Car Speaker Logo
Top Pioneer Car Audio & Video Experts
 Francisco Mauricio...
Ekse
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
