SOURCE: Error code 5800 for Pixma MP130. When try to get
you can try this:
Turn on the printer (MP130) and do the following:
1. Press MENU SCAN COPY SCAN to enter service mode
2. Use > to go to NVRAM ACCESS
3. Set ABS-M LEVEL to 0
4. Set ABS-P LEVEL to 0
5. Press STOP to exit
Done, hope it work.
SOURCE: Canon Pixma MP130 had message
Here is what the Caon site says:
Issue: ERROR LCD: CHECK PRINTER 5B00
Solution: Press
ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
Note: It may be necessary to unplug the
power cord if pressing the ON/OFF button does not shut off the
printer.
Here is the support link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp130#ServiceAndSupport
Please rate fIXYA
Thanks
SOURCE: canon mp130 showing invalid key/set
desliga o cabo de energia, segura o resset pressionado e coloca novamente o cabo de energia o menu sera desbloqueado.
