View and Download Durabrand CD2775SW operating instructions manual online. 5-cd ... Stereo System Durabrand 5 CD Changer Home Stereo System Operating ... PRECAUTION Follow the advice below for safe and appropriate operation.
Are you using an amplifier? If you are, it sounds like you are using the power antenna remote turn on (usually blue) instead of the amplifier remote turn on (usually blue/white). Leaving tuner mode when using the power antenna remote turn on turns the amplifier off.
If you are using an amplifier, make sure you are using the blue/white wire to turn the amp on instead of the blue wire. The blue wire is power antenna remote turn on and shuts off when leaving tuner mode.
Are you running your audio through an amplifier? If so, it sounds like you are using the blue wire instead of the blue/white wire to turn your amp on. The blue wire is power antenna remote turn on and turns off when leaving tuner mode. The blue/white wire is amplifier remote turn on.
Is the sound working fine for the radio? If so, are you using an amplifier? If you are using an amplifier make sure you are using the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on). The blue wire turns off when leaving tuner mode.
There is a switch inside the changer that will not release. Most likely the plastic stop it rides on has broken off . This is common when the changer keeps shuffling the disc all the time
are you running audio through an amplifier? if so, you may be using the wrong blue wire to turn the amp on. usually the amp remote wire is blue/white. solid blue is usually antenna remote, which turns off when leaving tuner mode.
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
