20 Most Recent Teac AG-V8060 Receiver Questions & Answers
How do you reset the blinking protect banner on
Try disconnecting the power cord then disconnect the speakers. Plug the power cord back in then hold in the power button until the unit "clicks." Then disconnect the power cord and reconnect the speakers, then the power cord and turn it back on.
2/21/2019 4:20:11 PM • Teac AG-V8060... • Answered on Feb 21, 2019
Why does my Teac receiver only light up the volume, then shut back off?
Your receiver has developed an internal short circuit and the unit is shutting down to prevent further damage. You might want to check the power supply for problems since it is a hard working area and prone to failure.
9/2/2015 1:47:52 AM • Teac AG-V8060... • Answered on Sep 02, 2015
Why dont i have sound
First , make sure the speaker switch is ON Second , make sure no TAPE MONITOR function is on. 3rd, Make sure ( if there is a Mute switch) , turn that off. If still nothing, try headphones and see if something comes through
2/27/2015 10:56:46 PM • Teac AG-V8060... • Answered on Feb 27, 2015
0answers
manual
Does fan motor run all the time
there should be a setting in the advanced setup menu to set fan to run all the time and to operate thermaly
6/25/2014 11:33:52 PM • Teac AG-V8060... • Answered on Jun 25, 2014
If fan fails will protect come on
If you are playing at loud volume levels , the power amp will overheat without a fan and you could VERY well get a major failure. I'm not sure about a thermal protection circuit on Overheat
5/27/2014 12:52:28 PM • Teac AG-V8060... • Answered on May 27, 2014
The sound through the speakers is very faint. Why can't i get more volume?
IS there a tape monitor switch on the Front Panel? Is it ON?..Turn it off Is there a MUTE function on the unit?...If so, turn it off Try those 1st
5/27/2014 12:50:50 PM • Teac AG-V8060... • Answered on May 27, 2014
2answers
Display says 'protect' and unit does not work. Is
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
5/24/2014 5:08:24 AM • Teac AG-V8060... • Answered on May 24, 2014
Does fan on amp need to be on all the time
Yes
5/24/2014 2:28:49 AM • Teac AG-V8060... • Answered on May 24, 2014
2answers
My unit says over load shut off power and turns off 2nd set of speakers???
Here are some things toy can check and try. Connection faults -- Check the speaker cables for shorts or damage. Crossing speaker wires can destroy receivers. Some units are sensitive to speaker polarity problems. Make sure both sets of speaker cables have the correct polarity. Very thick, or otherwise incorrect speaker cables can also cause faults like this. Try thinner wire if you are using very thick wires. You may have the wrong speakers. Check the resistance the unit expects (usually 4 or 8 ohms), and make sure it matches. Try different speakers. Could be other speaker faults. Some active speakers can develop faults, or there may be an internal fault in the speakers. Try different speakers. Thermal overload: -- As a general rule, don't run the second set of speakers if you don't need them - usually runningthem will degrade audio quality, increase power consumption, and increase the liklihood of thermal overload. Try listening on a lower volume, see if it still does it. I have a unit that behaves this way mostly in summer when it is warm. If it does not do it when the volume is low, that's an indicator it may be thermal overload. Check clearances. Don't block vents or place the unit in an enclosed space. Check the manual for a guide. Check for dust, you might need to open it, (This will void the warranty if any, and can be dangerous even if the power is disconnected). You may use an air blower (like in a can) to clear the dust - or carefully use a vacuum cleaner). If you suspect thermal overload, try pointing a domestic fan at the unit and see if it still does it. Internal fault -- Sometimes faults in the unit can cause these sort of symptoms. I've seem problems with volume knobs, and other parts. You'll need a proper service agent to investigate if this is suspected.
5/15/2014 6:10:04 AM • Teac AG-V8060... • Answered on May 15, 2014
0answers
0answers
0answers
Pre out connection/cable,. how to
Just put the amp jack in the RED socket if is marked or Right socket. It will not effect it, having the other one not used. But you can get a stereo to mono jack lead if you want.
3/22/2013 1:56:02 AM • Teac AG-V8060... • Answered on Mar 22, 2013
Teac AG-V8060 Receiver Logo
73 questions posted
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Audio Players & Recorders
Most Popular Question
teac receiver only light up volume shut
  • Audio Players & Recorders
