SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
SOURCE: error soak and scour light comes on wont wash
press and hols start button until it resets then try again.
have they checked the thernals on the bottom of the tub
SOURCE: Whirlpool Dishwasher Model GU2500XTPS1
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
1. Unplug dishwasher or disconnect power.
2. Check/replace control
SOURCE: my soak/scour light is blinking and cant get my
generally any time a button continuously flashes, you either have a bad door switch that doesnt recognize door closing, therefore will not start, or the electronic keyboard/touch pad is shorted out, in which case youll need to replace the console assy
