20 Most Recent Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher Questions & Answers
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Whirlpool 24 in.... | Answered on Aug 03, 2012
check for water leaks in electronics housing or severe condensation in same area. Also check for leaks aound drain pump area.
Whirlpool 24 in.... | Answered on Feb 01, 2012
Video, but a quick read makes me thing is is supposed to stay if it is the 'retainer clip'. Did you read the instructions and installation manual.
https://www.google.com/search?q=remove+the+door+packing+clip+from+a+whirlpool+dishwasher
Whirlpool... | Answered on Jun 27, 2020
SADLY CAN NOT AS A DIYER I NEVER HAD ON TO WORK WITH CHECK WITH WHIRLPOOL TECH SUPPORT
Whirlpool... | Answered on May 06, 2020
https://www.youtube.com/watch?v=eUD0HMC0OvI
https://www.hunker.com/13407814/what-causes-a-whirlpool-dishwasher-to-have-a-flashing-light
Whirlpool... | Answered on Apr 25, 2020
https://www.youtube.com/watch?v=l8GFXlVGY-8
Whirlpool... | Answered on Apr 14, 2020
All dishwashers are "tall' now. But will fit under counters wiring diagrams are glued to the inside of the panels
Whirlpool... | Answered on Feb 21, 2020
The problem may be stuck or failed "keye" or a stuck cycle timer or both.
Whirlpool... | Answered on Dec 17, 2019
Non 'per minute'!
It use 6 gallons 'per CYCLE'.
Whirlpool... | Answered on Dec 09, 2019
Whirlpool 24 in. GU2500XTPS Stainless Steel Built-in Dishwasher Logo
Popular Tags
20 questions posted
Top Whirlpool Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Marvin
Marvin
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
clean light blinking will not start
  • Dishwashers
