Question about Daewoo ERF336MB Freezer
It go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Posted on Mar 02, 2017
SOURCE: I have a Daewoo FRN U20DA type american fridge
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Posted on Feb 27, 2011
SOURCE: my daewoo FRSU20DCB has appeared to stop making
i have the same problem and have tried to contact daewoo on a number of occasions but only to be passed onto an engineer who wants to charge me min two hundred pounds
Posted on Mar 08, 2011
SOURCE: why does my daewoo fridge
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jul 24, 2011
SOURCE: Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Posted on Apr 29, 2012
Nov 23, 2015 | Freezers
Jul 09, 2015 | Maytag MBF1953YEW 18.5 cu. ft....
Aug 25, 2014 | Daewoo FRSU20IA Freezer
Jul 22, 2014 | Daewoo Freezers
Nov 01, 2013 | Freezers
Oct 19, 2013 | Whirlpool Freezers
Oct 06, 2013 | Samsung Fridge Freezer Water Filters Lg...
Apr 28, 2012 | Daewoo Freezers
Dec 23, 2017 | Daewoo Freezers
Aug 31, 2009 | Freezers
432 people viewed this question
