Question about Freezers
Water pools at bottom of freezer, freezes and water leaks out
We have a GE refrigerator/freezer where the freezer is below the fridge. The problem: water pools at the bottom of freezer, freezes and when the entire bottom of the freezer is full of ice, water leaks out onto the floor
Posted by mariafranco7 on
Mike Price
    President:
  • 744 Answers
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Aug 31, 2009
Why ismaytag bottom freezer leaking water?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Sep 05, 2014 | Maytag MBF2258XEW 21.9 cu. ft....
Why has my kenmore elite trio refrigerator started to intermittently started to chime
Hi! I am having this exact problem also. The best answer I have been able to discover is that it is related to the freezing up of the internal water tube that drains the fridge compartment into the freezer section. In addition, a pool of water freezes on the interior floor of my freezer and has to be manually chipped up and removed. I did try to unload the freezer and defrost it thoroughly, but it still happens and has to be chipped each week. I am still seeking a solution, but at least I can make the chiming stop by locking the temperature via the button on the front panel. Best wishes. If you discover a better or final soln, please post. I will do so as well.. Regards.
May 28, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
STANDING WATER UNDER DELI TRAY
Try going further than defrost and draining the hose. There is gunk that builds up and you need to clean that out. Use a pipe cleaner(the fuzzy wires used mostly for art projects. They actually can clean pipes and water lines!!) Also, you can pick up a pack of pellets used for breaking down the "gunk" build up.
Mar 06, 2014 | GE Profile : PFSF6PKXWW 25.5 cu.ft. Bottom...
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE side by side. Water leaking from bottom of freezer door. Fridge is cold. Freezer is fine. Ice maker fine. Only problem is the leaking water
It means that the freezer door is not closed will see the rubber frame it maybe broken some where or twisted .
If it's broken it must be changed but if it's twisted you can use some medical cotton roll it by your hands like a pen and insert it behind the frame.
I hope that help you. so sorry for my bad English.
Feb 12, 2013 | Freezers
GE top freezer refrigerator automatic ice cube maker leaks water into the freezer, and eventually on the floor. Water seems to be coming from the area that fill up to make more ice cubes.
If it is leaking water in the freezer it will more than likely freeze amongst the ice cubes causing a block of ice.
It is more than likely leaking at the rear of the unit, near the valve or fill tube for the ice, this will run up the rear wall of the unit.
Mar 12, 2009 | GE Freezers
GE used refrigerator....
I would try defrosting first. If no difference, or worse then you may have a refrigerant leak. You could always try setting back to the original setting. Hope this helps.
Aug 02, 2007 | GE Freezer  14.8 Cu. Ft. Manual...
Freezers Logo
590 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
