Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
My fridge leakes water. It seems to be keeping cold.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 18, 2009
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Jan 08, 2012 | KitchenAid Refrigerators
Aug 19, 2010 | Frigidaire FRT21P5A Top Freezer...
Mar 19, 2010 | Refrigerators
Feb 21, 2010 | Refrigerators
Feb 20, 2010 | Kenmore 64802 Top Freezer Refrigerator
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Dec 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Nov 08, 2008 | Whirlpool ET1FHTXM Top Freezer...
Feb 11, 2008 | Freezers
Feb 13, 2015 | Amana 22.6 cu. ft. Side-By-Side...
Jul 01, 2014 | Amana 22.6 cu. ft. Side-By-Side...
170 people viewed this question
is the drain hose in the drain pan?
