Question about Daewoo Freezers
Why does my daewoo fridge freezer works intermittently ?
My Daewoo american fridge feeezer works intermittently, I have noticed the ice melting in the ice maker, and sometimes (only sometimes) when I try to dispense ice (although ice is in it) the water pump engages and water is pumped out, I appreciate that only having one cooling circuit (i assume) that when the freezer dosnt work, the fridge also dosnt cool, im assuming that this is an electronic problem and its not the gas in the fridge freezer that is the problem,
Posted by jim cosgrove on
Keith Poitier
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 106 Answers
You either have a faulty thermostat, a loose connection or most likely a build up of ice inside the freezer. I had the same problem. Almost replaced fridge. Took all the food out one day, took out the racks and disassembled bottom and rear and found a two foot log block of ice inside air return. Removed ice everything works perfectly.
Posted on Jul 22, 2014
5 Related Answers
Anonymous
SOURCE: Floating bits in Whirlpool fridge-freezer crushed ice water
Ice cubes freeze from the outside, so the center of the cube is the last to freeze. Ice is pure water, only H 2 O, so as the ice cube freezes, all of the dissolved minerals are pushed to the center. Near the end of the freezing, there isn't much water left in the center of the cube, so these minerals become very concentrated, and they form the "white stuff" – the technical name is precipitate. The hardness minerals that cause the "white stuff" are not toxic.
Posted on Aug 30, 2009
Testimonial: "Brilliant - it all makes sense now! I'm 100 per cent satisfied that is what it's all about. Many thanks, erkes. You're a star..."
Anonymous
  • 185 Answers
SOURCE: The ice-maker in my Daewoo Fridge Freezer
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Posted on Mar 31, 2010
Testimonial: "Thank you, Matt. "
Anonymous
SOURCE: just bought DAEWOO FRS-U20DC,cannot get ice maker
how do i suse my model 230 gps
Posted on Aug 27, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: I have a Daewoo FRN U20DA type american fridge
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Posted on Feb 27, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Bosch FD8709 Fridge Freezer (American Style)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 05, 2011
Testimonial: "Thank you for your generous support. I found a lot of dust under the unit, turned it off, cleaned-up, and it appears to be working at the moment."
Ice maker problem daewoo frs-2031 IAL
I wouldn't buy a Daewoo fridge with Donald Trump's money!
Jun 27, 2016 | Daewoo Freezers
Daewoo frsu20iai freezer builds ice at bottom and starts to defrost some items?
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Aug 25, 2014 | Daewoo FRSU20IA Freezer
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Ice forming at bottom of Daewoo freezer. How do I fix this
Look on the back of the unit for a plastic hose coming out the bottom to a drain pan usually sat on top of the compressor. Bend a straw and push up inside. If it won;t go, there is a blockage, usually ice in the drain. Fully defrost the freezer and blow through the straw until clear.
Apr 28, 2012 | Daewoo Freezers
Daewoo FRSU20DCB not making ice
Sounds like you have an airflow issue. Freezer temp. should be @10-15 below and fresh food area @35-37 above zero You may have an evaporator fan or door switch failure
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
This link can help you diagnose your problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 23, 2017 | Daewoo Freezers
My Daewoo ERF 334M Fridge/Freezer has a little ice in the bottom of the freezer and is spilling water onto the floor - think it may be a blockage in the drainage pipe but do not know where this is located...
it go's down locate drain tube at bottom of freezer some time just defrosting manually will cure this drain gets small peace of food or tie from food freezes and blocks water from flowing warm water and a turkey baster works wounders
Aug 15, 2011 | Daewoo ERF336MB Freezer
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
Feb 26, 2011 | Daewoo Freezers
Daewoo frnu20da Water/ice dispenser supply
Makes no sense, you would be back and forth every twenty minutes.
Jul 23, 2010 | Freezers
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
Freezers Logo
658 people viewed this question
Top Daewoo Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Daewoo Freezer Expert? Answer questions, earn points and help others
