We have a kenmore elite 3 door. Water leaks into the bottom of the freezer forming a sheet of ice then leaking onto the floor. Ice maker works but slow.
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 16, 2009
Sep 21, 2015 | Refrigerators
Jun 09, 2015 | Refrigerators
Oct 21, 2017 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Apr 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dec 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Aug 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Mar 16, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jul 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Dec 20, 2020 | Kenmore Refrigerators
432 people viewed this question
