My Daewoo FRSU20DCB is not making ice both fridge freezer are cold but not cool enough, I am also making my own ice in the middle of the freezer it's making ice but it's still has water in the middle of the ice it's been there over night. Temperatures in use: Fridge 6 (full) Freezer -21
Sounds like you have an airflow issue. Freezer temp. should be @10-15 below and fresh food area @35-37 above zero You may have an evaporator fan or door switch failure
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
This link can help you diagnose your problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Posted on Dec 31, 2017
SOURCE: fridge not cooling
how would you test to determine which of the three
Posted on Jul 19, 2008
SOURCE: amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Posted on Aug 05, 2008
SOURCE: Fridge not getting cold
unplug unit to "reset." pull unit out from wall and blow the coils out on the back of refrigerator. if that does not work- call service man to come check freon level.
Posted on Aug 09, 2009
SOURCE: The ice-maker in my Daewoo Fridge Freezer
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Posted on Mar 31, 2010
Testimonial: "Thank you, Matt. "
SOURCE: my daewoo FRSU20DCB has appeared to stop making
i have the same problem and have tried to contact daewoo on a number of occasions but only to be passed onto an engineer who wants to charge me min two hundred pounds
Posted on Mar 08, 2011
Jun 27, 2016 | Daewoo Freezers
Jul 22, 2014 | Daewoo Freezers
Mar 25, 2013 | Daewoo FRSU20IA Freezer
Apr 05, 2011 | Frigidaire Freezers
Mar 08, 2011 | Daewoo Freezers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Daewoo FRSU20IA Freezer
Jun 23, 2010 | Freezers
Jan 16, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Sep 09, 2009 | Whirlpool Freezers
Dec 29, 2012 | Daewoo Freezers
695 people viewed this question
Update:
1. The pipe that supplies water to ice maker is hot.
2. Does any one know how to get to the freezer fan motor? is it from the inside of the freezer?
When the freezer door is shut the fan moves for a few seconds and stops, it's not running at full speed.
hav u had any look tommy am havin same probs
Alan are you also getting frost at the back of the freezer.
