20 Most Recent
Porter Cable Moen Legend, Single-Handle Kitchen Faucet with Cast Bar Construction and Black Protege Side Spray - 7310 Questions & Answers
We are trying to replace our Moen Adler Faucet and
first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
Portercable Pressure Washer Model PCH2401
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Porter cale drill and two
If the charger got wet, or you tried to charge batteries that got wet... yes. Replace the charger, and throw away or recycle the water damaged batteries. I know thats not what you wanted to hear, but look at the bright side! The drill is most likley fine!
The knob that adjusts pressure
Hi bluejuice86...
You may have lost a small part that goes inside of the pressure adjuster.
You will save time and effort, replace it with a new pressure adjuster...you can get them from HomeDepot,Loews,Ace Hardware,etc.
Please take time to rate me
Husband is out of town
Switch drill to reverse, grab drill head tight, do not grab bit, pull trigger, chuck will open, switch to forward center new bit hold head tight pull trigger. Make sure bit stays in center, Let me know if this helps.
Have a porter cable 3x21
on the front wheel , there is a screw that you can adjust ,, that will adjust the tracking of the front wheel, the rear wheel is stationary , once you have the new belt on, locate that screw,, and just click the switch as you adjust it,, once adjusted, you will see that it tracks straight and won't fall off
I need to replace a
I believe you push the front roller until it clicks, then slide old belt off. Then push to release lock
