20 Most Recent Porter Cable Cable Commercial Pressure Washer PCH3200 Questions & Answers
Your description describes a "No Fuel" problem. Start at the fuel tank and move on to the carburetor. At the fuel tank check that the fuel shut-off valve is open (if applicable). Inside the fuel tank, attached to the pet-cock, is a filter (check that it is clear). Look for kinks in the fuel-line (kinks would prevent fuel flow). Last would be the carburetor. If the carburetor is dirty or clogged, it will need to be removed, serviced, or replaced. Good luck. P.S. If this is a newer unit then use care. Do not use Carburetor cleaner on it. Because of the plastic components, it will ruin the carburetor. Instead, go to the parts store and request a product called "Seafoam". It comes in a red and white can and is great. It is slow working so the carburetor will have to soak overnight. Please let me know how the repair goes.
Porter Cable... | Answered on Mar 11, 2014
If you need an engine manual, then look up the manual on the engine manufacturer's web site. eg Briggs & Stratton, Honda, Techumseh. Porter Cable manual would just have cart and pump info.
Porter Cable... | Answered on Jul 23, 2010
check the seals and o rings on the connections could be sucking air
Porter Cable... | Answered on Nov 13, 2009
check your in take screen make sure its not plugged, look for calcium build up. then check your valve there should be six of them. my be damaged or weiring out and or plunged. if all looks good you'll need to check your unload-er valve. check your oil to make sure no water is in there, ok. good luck, let me know.
Porter Cable... | Answered on Oct 16, 2009
non return valve on syphon injector on high pressure outlet stuck or 'o' ring worn. remove barb should be a spring and ball bearing in there.
it may be that the spring has broken too.
new non return valves are available.
Porter Cable... | Answered on Jul 18, 2009
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Porter Cable... | Answered on Apr 25, 2017
Try some blue LocTite thread fastener. It's an anaerobic-hardening resin. Remove the knob enough to get a drop onto the threads, then snug it up. Going forward, repeat as necessary. Just a drop.
Better than lock-washers. Scrollsaws basically just vibrate their little blades up & down.
Porter Cable... | Answered on Jun 11, 2016
If the charger got wet, or you tried to charge batteries that got wet... yes. Replace the charger, and throw away or recycle the water damaged batteries. I know thats not what you wanted to hear, but look at the bright side! The drill is most likley fine!
Porter Cable... | Answered on Sep 26, 2011
Hi bluejuice86...
You may have lost a small part that goes inside of the pressure adjuster.
You will save time and effort, replace it with a new pressure adjuster...you can get them from HomeDepot,Loews,Ace Hardware,etc.
Please take time to rate me
Porter Cable... | Answered on Sep 16, 2011
Porter Cable Cable Commercial Pressure Washer PCH3200 Logo
Popular Tags
10 questions posted
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
View Most Popular
Porter Cable Garden
  • Porter Cable Garden
Most Popular Question
stay running
  • Garden
