20 Most Recent Porter Cable Cable Premium Pressure Washer PCV2500 Questions & Answers
IT COULD BE OUT OF TIME .
Porter Cable... | Answered on Oct 13, 2019
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Porter Cable... | Answered on Apr 25, 2017
Try some blue LocTite thread fastener. It's an anaerobic-hardening resin. Remove the knob enough to get a drop onto the threads, then snug it up. Going forward, repeat as necessary. Just a drop.
Better than lock-washers. Scrollsaws basically just vibrate their little blades up & down.
Porter Cable... | Answered on Jun 11, 2016
If the charger got wet, or you tried to charge batteries that got wet... yes. Replace the charger, and throw away or recycle the water damaged batteries. I know thats not what you wanted to hear, but look at the bright side! The drill is most likley fine!
Porter Cable... | Answered on Sep 26, 2011
Hi bluejuice86...
You may have lost a small part that goes inside of the pressure adjuster.
You will save time and effort, replace it with a new pressure adjuster...you can get them from HomeDepot,Loews,Ace Hardware,etc.
Please take time to rate me
Porter Cable... | Answered on Sep 16, 2011
Switch drill to reverse, grab drill head tight, do not grab bit, pull trigger, chuck will open, switch to forward center new bit hold head tight pull trigger. Make sure bit stays in center, Let me know if this helps.
Porter Cable... | Answered on Sep 05, 2011
Hi blackswamp...
Go to the following webpage and get the phone number to talk to a live person at Porter Cable.
http://gethuman.com/Delta_Porter_cable-customer-service_2122.html
Porter Cable... | Answered on Aug 31, 2011
on the front wheel , there is a screw that you can adjust ,, that will adjust the tracking of the front wheel, the rear wheel is stationary , once you have the new belt on, locate that screw,, and just click the switch as you adjust it,, once adjusted, you will see that it tracks straight and won't fall off
Porter Cable... | Answered on Aug 26, 2011
Might have a broken firing pin.
Porter Cable... | Answered on Aug 25, 2011
I believe you push the front roller until it clicks, then slide old belt off. Then push to release lock
Porter Cable... | Answered on Jul 19, 2011
Porter Cable Cable Premium Pressure Washer PCV2500 Logo
Popular Tags
2 questions posted
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
View Most Popular
Porter Cable Garden
  • Porter Cable Garden
Most Popular Question
porter cable sawsall blade broke off
  • Garden
