Question about Porter Cable Garden
I have a porter cable sawsall and the blade broke off right at the quick release. I've tried pulling the release off to get the blade out but the bearing will not let go of the blade. Any ideas?
Posted by Dave Armstrong on
Nater13
    Master:
  • 610 Answers
Use a safety pin (one of the larger, stout versions) to poke into the assembly and depress the retention bearing...
Posted on Jul 20, 2016
4 Related Answers
dontbother10
dontbother10
  • 2220 Answers
SOURCE: broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Posted on Sep 14, 2009
Anonymous
  • 59 Answers
SOURCE: I have a Porter cable Tiger Claw saw model 9750.
detent latch broken
Posted on Nov 22, 2009
Anonymous
  • 5 Answers
SOURCE: Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Posted on Dec 08, 2009
canwoodjc
Canwoodjc
  • 3301 Answers
SOURCE: Blade will not release on
ok first this is in the chainsaw category and since they don't make one,, I'll assume you mean a sawzall, if you have the quick release ( which is a joke and is a bad part ) your going to have to breal off the blade at the section that it reduces ( where it goes into the holder) unscrew the ringnut that releases the blade, and take it all apart. be careful there is a ballbearing sitting inside there that will roll right out and naturally get lost in the mix. once apart you can remove the last of the blade. Now if your really lucky, you can clean it,, lightly oil this piece , and reassemble it,, and it will work, I have 3 and have replaced that part on all 3 of them,, Now if its an older model that still has the set screw hold down,, Just unscrew the setscrews and remove the blade, ( some have 2 some just one set screw depending on the model
Posted on Jul 03, 2011
Cannot get the blade out of the porter cable reciprocating saw
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
May 27, 2010 | Porter Cable Variable Speed Quik Change...
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Need to change the blade on my sawsall
Make sure the cord is out of the plug! grasp the knob where the blade enters the machine, turn it 1/4 turn R or L and pull the blade out
Sep 29, 2009 | Porter Cable Variable Speed All-Purpose...
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
Plugged electric sawzhall in, no power. checked cable -- ok, checked both brushes, still have about 3/8in in each of them. What should I do next? Just replaced the blade, but I do not think that has...
I would say its either in your cord(an open wire from wear) or the switch on the sawsall.
Try plugging it in and hold in the switch (dont have a blade in) move the cord around in different places to try to get it to work if thats not it and your brushes are ok its probably the switch. I ve replace bad switches in sawsalls before from wear. You can either go to your local electrical supply store that sells milwaukee and order one or I ve purchase them at Grainger parts too.
Jun 29, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Broken blade on a porter cable 737 tiger
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
The saw blade on my Porter cable 423mag saw is jammed tight.
Unless you can get a wrench on it I can't see anything else on the breakdown. You are aware that the knob is Left Hand thread I hope.
Mar 22, 2009 | Porter Cable Saws
Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
Jan 21, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Garden Logo
138 people viewed this question
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
