Question about Porter Cable Garden
I have a porter cable 16' variable scroll saw. the tension knob on the back will not stay in place, hence making the blade loose, how can I fix this.
It is running really rough as well, like running a chain saw
Posted by Sharon Allen on
john barry
    New Friend:
  • 23 Answers
Try some blue LocTite thread fastener. It's an anaerobic-hardening resin. Remove the knob enough to get a drop onto the threads, then snug it up. Going forward, repeat as necessary. Just a drop.
Better than lock-washers. Scrollsaws basically just vibrate their little blades up & down.
Posted on Jun 11, 2016
5 Related Answers
Anonymous
  • 52 Answers
SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
Anonymous
  • 63 Answers
SOURCE: Homelite 16'' chain saw runs rough and backfires
One of two things is wrong. This saw is so old I doubt it has electronic ignition. Pull the flywheel off and clean the points with carb cleaner and sand the contacts very, very lightly with super fine sandpaper or a little file. Second option, the coil is bad, take it to the shop and they should be able to test it for you.
Posted on Mar 16, 2009
firesnake09
Melvin Ramos
  • 2923 Answers
SOURCE: Owners Manual for a Remington 2.5 HP 16 '' Chain saw, Model EL-7
Kindly check this link for manual. Please select the correct model:
http://lawnandgarden.owneriq.net/manuals/mfg/remington/remington_chainsaw_product_list.html
Posted on Apr 18, 2009
Anonymous
  • 188 Answers
SOURCE: How do you adjust chain tension?
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Posted on Jul 01, 2009
Anonymous
SOURCE: poulan chain saw will not stay running after i sta...
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
Posted on Jun 11, 2010
Porter cable scroll saw runs slow
If you bypass the speed control does it run/spin up like before?
Sep 12, 2016 | PorterCable 1.6-Amp Variable Speed Scroll...
Changing blade scroll saw
Loosen the knob at the rear of the top arm - turn it counterclockwise several turns. The blade should now be loose. Push the "blade end" of the top arm down slightly with one hand while you unhook the top of the blade. Lower the blade a little to unhook it from the bottom arm.
Replace the blade. Hook it onto the lower arm first - you can look underneath to see what you're doing. The blade's teeth should point DOWNWARD - it's easy to accidentally install it the wrong way, so check that now. Again push down slightly on the end of the upper arm, then hook the top of the blade into the upper arm's blade holder. It should how stay in place, but loosely.
Now return to that tensioning knob at the top rear. Tighten it slowly until the blade is BARELY tight, not loose. Tighten the knob 1/2-turn to one full turn tighter to tension the blade.
Jul 24, 2014 | Craftsman 16" Variable Speed Scroll Saw
My Dewalt 788 Scroll Saw table has a problem: It's fine when level, but when inclining the table left, it contacts the blade. That's when I noticed there's vertical play in the table; the
First: if there is looseness in the table, it is dangerous. So I would check all the parts for wear. If, for instance, a knob worked loose, the bolt could have worn (via vibrating) the bracket, resulting in you being unable to tighten it correctly. Occasionally I take mine all apart and check it all over for just that reason. I also check all the knobs just before use to make sure they are all tight. Here is a web page talking about Dewalt scroll saw problems and solutions http://www.scrollsaws.com/SawReviews/DewltTuneUp.htm
Jan 03, 2018 | Dewalt DW788 Heavy Duty 20" Variable Speed...
My Craftsman 16" variable speed scroll saw worked fine the last time I used it. I tried to use it yesterday and now suddenly it seems to have the bottom arm of the saw working in opposition to the upper...
Try retightening the tension knob...not sure exactly hows its hooked on,but sounds like you may have backed it out too far.If simply turning the knob to tighten does'nt work,try either pulling up on knob a little while trying to tighten..or opposite-push down on it while trying to tighten...the idea with both is to get the threads on the tightening knob to catch the nut inside...my guess is it came off.
Aug 23, 2010 | Craftsman 16" Variable Speed Scroll Saw
How to change the blade on a craftsman scroll saw? The manual was been misplaced when we moved
You might be able to find the manual on the Sears site (this can be a frustrating search - but start with the model number). But even without the manual, this is pretty easy on most scroll saws. There is usually a plastic knob (about the size of a ketchup bottle lid) on top of the machine at the back. You loosen this knob a couple of turns (to the left) and the blade will become very loose. The blade is probably the "pin-end" type - it will have a little cylinder about a 1/4 inch long on each end of the blade. You can buy new blades at any home improvement or hardware store. Besides qualtiy, the main differences will be the length of the blade and the size of the teeth (expressed as TPI or Teeth Per Inch). You need more TPI for cutting harder and thinnner materials, less TPI for softer and thicker material. Put the new blade in like the old one was (teeth pointing down) and tighten the plastic knob. It's hard to be sure how tight is should be, since it doesn't suddenly tighten up. About a 1/4 turn past where is starts to get noticeably tighter is a reasonable place to start. If the blade pops off during use, it wasn't tight enough.
Jan 14, 2010 | Craftsman 16" Variable Speed Scroll Saw
Saw has no power.
Does the motor continue to run, but the arm stops? It sounds like the set screw on the motor shaft is loose. See the exploded view at this link. It's called out as # 97 http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=5682&typeId=3475&documentId=333
Jan 13, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Need to change the blade on my sawsall
Make sure the cord is out of the plug! grasp the knob where the blade enters the machine, turn it 1/4 turn R or L and pull the blade out
Sep 29, 2009 | Porter Cable Variable Speed All-Purpose...
Garden Logo
125 people viewed this question
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
