Question about Porter Cable Garden
NEED TO LUBRICATE PORTER CABLE 548 SAW
HOW DO I LUBRICATE THIS SAW? WHAT LUBRICANT? OIL OR GREASE?
5 Related Answers
dontbother10
dontbother10
  • 2220 Answers
SOURCE: husvarna chainsaw hole in oil lubrication tank
J-B Weld is probably your best option. Cleaning it so it adheres properly is the hard part. Did you ask your local Husky dealer? They may have some options the average owner does not. Phone calls are inexpensive.
Probably cast aluminum, maybe magnesium. HTH and Good Luck.
Lou
Posted on Feb 16, 2010
Testimonial: "thank you for your help problem is now solved"
dontbother10
dontbother10
  • 2220 Answers
SOURCE: My chain saw is not lubricated properly. I have
I concede you have already performed all but the last sentence of part 1.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
I further concede when you do there is no oil ooze. If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL). An example of a Poulan "PP4218AVHD Gas Saw Type 2" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4218AVHD-Gas-Saw-Type-2/75.PP4218AVHD-Gas-Saw-Type-2.1.59.1.html
See the "Handle, Chassis and Bar Assembly" print, item 61 is the pump and item 62 the gear. Both parts are located behind the inboard clutch. Start clutch removal like this:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
The remaining pieces are using this as a guide:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If the example is not your you can find yours here:
The IPL (exploded parts list) for your saw is the only detail for oil
line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 04, 2010
Anonymous
  • 3 Answers
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
Anonymous
SOURCE: What lubricant oil is used on the blade of a Wen
I have a Wen 2000 10" electric chainsaw and just ordered a new chain, , but does it need oil poured inside? I have no manual. what kind and how much? can it be over filled, there is a black screw off knob that appears to be for oil?????thanks Kim
Posted on Jun 21, 2010
Joe Hogan
  • 10865 Answers
SOURCE: what kind of oil or lubricant is required on a
Hi. Use any brand name bar and chain oil for your pole saw. Usually this oil is only sold by the gallon....so you may have quite a supply on hand. J.
Posted on Aug 01, 2010
My porter cable rn175 roof nailer keeps jamming the nails.I release the jammed nails and it does it again in just a few minutes. do they need to be cleaned with a special type of cleaner
Or wrong nails or the driver has a problem or the nail feeder /slider of the nails does not work properly, oil the tools by an Wilkerson oil atomizer with a special pneumolube after cleaned and basic lubrication
Clean inside all parts and use an good sillicon grease the cilinder piston ring and other orings with something like type of oks1110 on all moving parts priority in the upper parts above the cilinder and the ring s and o-rings control them they should not be worn or hardened out or worn
otherwise there is another option
BEWARE Only if there is NO real damage to the metal parts by using possible jamming wrong nails then is doing a self service possible
Porter-Cable DRIVER MAINT KIT 903769
Aug 21, 2018 | Porter Cable Air Tools & Compressors
My porter cable gun will not shoot nails
remove the 4 screws from the top and clean the surface of the moving membrane upper parts and o-rings the o-rings should not be worn or hardened , replace if they worn above the cilinder clean and grease it with a basic silicon grease like oks 1110 or some other faucet greases as basic lubrication and use regularly a pneumolube oil preferably in a Wilkerson
wilkerson-rn3iozsceve5bftnlsdmedju-5-0.jpeg oil atomizer
What are oil lubricators?
Industrial lubricants market is full of options today. From a variety of automotive & industrial lubricants and specialty products & lube additives, all kinds of lubrication needs are met here. Oil lubricator is a unique blend to enhance performance of the machine & equipment's.
Sep 18, 2014 | Health & Beauty
How do Oil Lubrictors help in functioning of machines ?
The lubricants surely work as a magical wand between the friction and the moving parts of machinery. So it is necessary to look for best oil lubricator for the smooth running of machines. Home FDJohnson
Jul 19, 2014 | Porter Cable Cable 135 PSI, 60 Gal. Oil -...
How to change oil
The is no oil insite to change only grease a special bosch lubrication or and the ballbearings insite have grease but you can also lubricate the transmission with Paragon Renolith from Dewalt easier to find in you country , simple ball bearing grease can also, but when its getting hot look at your electric field and also the armature if that color is correct nice brass colored thread windings instead of brown black colored and the commutator (collectors) on the armature is nice the place where the carbon brushes are on the armature are nice colored .because the tool can be on its end .if its noisy and if its worth to repair be aware before repair. how old is the tool or have it second hand bought its maybe a problem.
Mar 28, 2014 | Bosch "1677M 1677M, 7-1/4"" Worm Drive...
I have a Milwaukee circular saw model 6365. It still cuts fine, but it squeals loudly (like a little girl) when running. Sorry, couldn't help myself. Seems like the motor bearing(s) need lubrication. ...
You can try to lube the bushings, but they will always start to squeal again. I have tried just about everything, 2 cycle oil works good, wd-40 is a little thin, blaster works ok for a while, reg 3m oil forget it, motor oil, no, white grease, hard to get in there, axle grease, yes, but you have to take the bushings out. The oils, you don't have to take the saw apart. Hope this helps.
Aug 18, 2010 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
I have a Porter Cable 345 6" saw "3" series. Do I need to oil this baby?
unless it has a gearbox with a plug, no. the bearing are sealed. where the saw breaks down the middle, the metal part from the plastic part, there is grease in that gear compartment.
Jul 11, 2010 | Porter Cable 345 6" Circular Saw Saw Boss
Porter Cable Random Orbital Sander rotates but does not "orbit"
Just solved my problem with Porter Cable 333 orbital sander which just groaned. I thought the worst. I carefully took it apart on the garage floor and immediately suspected it needed lubrication as the motor turned hard. I used my flexible long plastic tube lubrication and put some on the bottom bearing shaft the best I could. I worked it around and around. I began to feel it turning easier. I applied more oil and kept moving and it became completely free. I put a drop on the top bearing even though it was loose. I put it all back together and it works like new. Lesson: do not look for the worst when a tool quits. Suspect the culprit to be lack of lubrication!!!
May 20, 2009 | Porter Cable 332K Quicksand Random Orbit...
Garden Logo
69 people viewed this question
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
