20 Most Recent Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P Questions & Answers
You can try spraying some lubricant into the blade holder. Sometimes the "ball" in the shaft gets stuck from dirt. Otherwise you will need to disassemble it by removing the roll pin that holds the collar on the shaft.
Porter Cable... | Answered on Jun 19, 2014
use a pair of tweezer to pull it out or a magnit
Porter Cable... | Answered on Aug 22, 2012
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Porter Cable... | Answered on Mar 04, 2012
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~
Porter Cable... | Answered on Feb 21, 2012
use sewing machine oil, or 3 in 1 oil, you could use WD40 as well. but not motor oil
Porter Cable... | Answered on Mar 22, 2011
Make sure the cord is out of the plug! grasp the knob where the blade enters the machine, turn it 1/4 turn R or L and pull the blade out
Porter Cable... | Answered on Sep 29, 2009
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Porter Cable... | Answered on Sep 14, 2009
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Porter Cable... | Answered on Sep 11, 2009
At the base of the blade where it attaches in the saw you will see a round in shape with ridges fixture. Turn it so the slot is in line with the blade. Then you will be able to remove the blade. If the fixture does not turn, move the blade up and down while you turn the fixture.
Porter Cable... | Answered on Jun 19, 2009
IT COULD BE OUT OF TIME .
Porter Cable... | Answered on Oct 13, 2019
when the trigger for the wand is not pulled , there is a pressure relief valve that bypasses the water in the pump and so there is no pressure until the trigger is pulled again.
with the pump getting hot and not being able to pull the motor to restart, it indicates that that pressure relief valve has jammed ( faulty ) and the pump is running at full pressure all the time
That will heat the pump and stop the engine from restarting
That valve is where I would start looking for a problem
Porter Cable... | Answered on Apr 25, 2017
Try some blue LocTite thread fastener. It's an anaerobic-hardening resin. Remove the knob enough to get a drop onto the threads, then snug it up. Going forward, repeat as necessary. Just a drop.
Better than lock-washers. Scrollsaws basically just vibrate their little blades up & down.
Porter Cable... | Answered on Jun 11, 2016
Porter Cable Variable Speed All-Purpose Tiger Saw Kit With Quick-Change Blade Clamp And Case 9737P Logo
20 questions posted
Top Porter Cable Garden Experts
JOHN LAPIER
ray gallant
Are you a Porter Cable Garden Expert? Answer questions, earn points and help others
View Most Popular
Porter Cable Garden
  • Porter Cable Garden
Most Popular Question
off front off porter cable tiger 747
  • Garden
