20 Most Recent GE / Caddx Networx NX 6 Control Panel With NX 1308E LED Keypad & Transformer NX6KIT Questions & Answers
I pressed the 'exit' button this morning and then heard the 'alarm turning on' sound, but the 'exit' button didn't light up. then I went outside and had to return to the ho
Your door sensor is not working so your alarm is unaware that you have left/returned.
3/30/2017 5:02:06 AM • GE / Caddx... • Answered on Mar 30, 2017
Motion detector is not working for GE INTERLOGICX 60-806-95R
All wireless security motions have a 3 min delay built into them. This means that whether the alarm is set or not when the motion detector picks up motion it shuts down for 3 min and will not pick up motion. This is done to conserve battery power. So I always advise customers to arm the system and stay away from the motion for 3 min total. example: 60 sec to arm system + 2min wait time. then try to trigger motion. If this does not help and assuming batteries are good, you'll need to replace motion. Good luck. This may help https://al.ly/vR54zP
12/15/2019 10:15:53 PM • GE Home Security • Answered on Dec 15, 2019
Locked In! GE SImon XT Doors & Windows - not taking code(s). Code(s) work to set date/time, but when trying to disarm "doors & windows - no entry" condition, no code works. No characters display.
I would start by power cycling your system. Remove the battery & power. After waiting 10 minutes or so reconnect the battery and then power. Other than that you need to be a bit more specific with your issues.
5/3/2019 7:01:09 PM • GE Home Security • Answered on May 03, 2019
Ge security system says service and the red fire light is on but there is no fire.
Try disarming system twice to get the fire zone to reset. If that doesn't work, try to downpower the entire system, including back up battery then re-power the system with the back up battery first.
10/24/2018 1:30:36 PM • GE Home Security • Answered on Oct 24, 2018
How reset dvsr admin password to default settings
First of all, here is the direct link to the ONLINE USER'S MANUAL for that model:
http://www.novisec.nl/cms/component/option,com_docman/task,doc_view/gid,67/
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 17 of the ONLINE USER'S MANUAL for detailed instructions on how to reset the unit to default settings. Basically it says:
Push the MENU button, select admin and enter 3477 for the password, then press OK to confirm.
Use the arrow keys to navigate to UTILITIES, then press ENTER.
Then navigate to RESTOREPARA and press ENTER.
Then select OK to confirm and the system will automatically reboot.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
10/8/2018 12:05:04 PM • GE Home Security • Answered on Oct 08, 2018
Hi, i have a ge simon xt alarm... i want to disconect one of the sensers...it wont let me do that...what do i do?
you need to get the installer code, then enter programming mode to delete the sensor.
3/28/2018 5:17:08 PM • GE Home Security • Answered on Mar 28, 2018
Cannot log in to web interface for DVR30 with IE 9
Try updating IE to the latest version if not you can try firefox or google chrome check the manufacturers docs to see if they require a certain web browser.
8/30/2017 10:16:59 AM • GE Home Security • Answered on Aug 30, 2017
GE Simon 3 door contact Where can I purchase a replacement?
Call GE for parts. Sears also has repair service for GE.
7/19/2017 5:22:26 AM • GE Home Security • Answered on Jul 19, 2017
I need to reset the alarm on my GE personal security window or door alarm
press the "status" button. If it is a Simon XT , press "disarm" then "status"
6/9/2017 4:35:09 PM • GE Home Security • Answered on Jun 09, 2017
tip
GE RANDOM VACATION TIMER GE5111N-71D also known as GE5111N
VERY straight forward setup. SET the Dial to the correct DAY of the week and TIME. This timer is PRESET at the factory and you can NOT adjust any other ON/OFF settings yourself! "Pre-Set" mostly for evening and later evening times or hours "ON/OFF". These times CHANGE from evening to evening and again, ALL settings are made by GE! ALL ON/OFF cycles change from evening-to-evening and day-to-day. 120VAC operation. SWITCHES: 1,875 WATTS MAXIMUM! 1,250 WATTS if you connect INCANDESCENT LAMPS! I hunted and hunted for the specs on this Timer, but found none. I finally purchased two and read the tiny manual. I set one up in the kitchen to TEST with a 50 Watt lamp and it works GREAT... I just don't know WHEN it will cycle next, but I guess that's the mission and point of these spiffy timers! SOGLAD
on May 15, 2017 • GE Home Security
GE 45233 wireless color camera to Android
I assume you want to monitor the camera from Android, unfortunately I'm not sure this is possible because the camera you have is not an independent camera or webcam, it is intended as a add-on for GE Color or B/W wireless systems (45234, 45235, 45236.) https://byjasco.com/sites/default/files/product/manuals/45233-Manual-Eng.pdf It looks like the camera transmits to the receiver. GE 45234 User Manual
1/31/2017 7:49:41 AM • GE Home Security • Answered on Jan 31, 2017
GE / Caddx Networx NX 6 Control Panel With NX 1308E LED Keypad & Transformer   NX6KIT Logo
3 questions posted
Top GE Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Home Security Expert? Answer questions, earn points and help others
View Most Popular
GE Home Security
  • GE Home Security
Most Popular Question
pressed 39 exit 39 button morning
  • Home Security
