Question about GE Home Security
Ge security system says service and the red fire light is on but there is no fire.
Posted by shannon on
Roy McCracken
    New Friend:
  • 59 Answers
Try disarming system twice to get the fire zone to reset. If that doesn't work, try to downpower the entire system, including back up battery then re-power the system with the back up battery first.
Posted on Oct 24, 2018
Security light on and won,t turn over engine to start . rolled car on to the roof on black ice. physically car looks ok
Car Won't Start Because of Anti-Theft System ... - RepairPal
repairpal.com > Problems > Oldsmobile > 88
Car Won't Start and Security Light is On on Oldsmobile 88 ... key turns over enginebut fails to start some times..security system keeps the fuel injectors from ...
repairpal.com > Problems > Buick > LeSabre
Car Won't Start and Security Light is On on Buick LeSabre. Problems with the ... 1998 Buick LeSabreVisitor. Turn key on every thing come on but won't turn over.
repairpal.com > Problems > Pontiac > Bonneville
Replaced trans, engine, PCM and bcm, now starter diabled- theft flashes on service ...1995 Bonneville car turns over but wont fire an security light is flashing car ...
GM Passlock Security Light Issues - RepairPal
Dec 26, 2015 | Cars & Trucks
How do you replace the battery for the vista 15pmt system. I have the low battery light
Open the control box and the 12V 4AH battery is inside. Buty new battery connect black and red wires to black and red terminals on the battery
AlarmProfessor.net
Nov 08, 2009 | GE Security Simon 3 Wireless Home Security...
GE networX security command center keyupad is frozen. I have 2. We replaced the battery that was needed, but before that was done the keypad froze with a shimmering light in the fire zone and a yellow...
since you did not list the model I cannot be certain this will help you, however if it is the correct model then there is a service section on page 16 that should help. http://www.elvey.co.za/ProductFiles/d9726436-02b3-48ae-894f-0e03b2e6c072.pdf
Sep 30, 2009 | Computers & Internet
Alarm goes off went armed as well as strobe won't go into armed mode
Smoke sensors will trip if dust accumulates in them. Get a can of compressed air like they sell for cleaning the vents in computers and try blowing the dust out. That should reset your sensors, If not you could disable the fire sensors for your trip and get it serviced when you return.
May 29, 2009 | GE Security Simon 3 Wireless Home Security...
Telephone disconnected from first alert professional alarm system
The phone wires run from directly from the telephone company connection to the alarm on the red and green. They return on the other two wires. These wires are hooked to your home phones. That's the UL way to do it. The alarm is supposed to be the first device on the telephone line. You can just run a phone line to the alarm panel. There probably is a diagram inside the cabinet door or a phone jack very near the alarm.
Apr 11, 2009 | First Alert SA302 Dual System Smoke...
Gas range does not light up (no clicking)
There is a transformer in it that bumps the 120vac house voltage to 230 volts. I'm 98% positive the transformer is bad and it was more than likely caused by a power company surge. I suggest calling for service since it is Monogram. It is more complex to work on. That said, I would ONLY trust GE Factory Service 1-800-432-2737 or schedule online at www.geappliances.com to have it fixed.
Nov 17, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE simon security system
Depends. Do you mean the chime? If all that is missing is the chime whenever a zone is tripped then simply press the CHIME button on the front panel. If it is lighted solid red then your chime is on and it will talk to you. If chime is off then it wont talk to you at all when a zone is tripped. Good luck.
Mar 09, 2008 | GE Security Simon 3 Wireless Home Security...
DTIM with digial phone service
I install these types of alarms.
First, What is usuallly plugged into the cables main box? Usually it is a jack. This would run to the main phone lines in the house, and allow you to have service at alll the jacks in the house. If this was not the case, then you usually just plug your phone in directly. Either way, the tel #1/2 on the main box is the same principal as the two main lines comming in off the street with the phone company. If there is a jack, get another and a peice of 2/4 strand wire. (If you have a 8 pin bell jack let me know if not follow.) connect the red and green at the main jack to the red and green of the new jack. Plug in the DTIM and go. If it is just a plug in the phone directly then i suggest getting three jacks. plug a regular phone cable from tel 1/2 into the first jack. Then connect the red and green to the next red and green. this is the DTIM jack. Then do the same to connect a phone jack for your phone. I have installed lots of simon 3 systems but never with a DTIM> I also install alot of GE Allegro panels and they come with the DTIMs. Are you having it learn in properly? It should be group 39 on the system. At least it is on the other panels.
Good luck.
Sep 08, 2007 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
232 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
